July 21, 2021, 06:57 |
mapFields returns an inconsistent field
#1 | |
Rep Power: 5 |
Hello everyone !!
I have a problem using mapFields. My source mesh size is 149.310 and my target mesh size is 8.958.600, it's a lot ^_^' Unfortunately, it's seems that mapFields returns a fields with only 4.777.920. I got this message. Quote:
Thank you |
July 21, 2021, 07:45 |
#2 | |
Rep Power: 5 |
Strangely, I got the same with much smaller mesh. This time, I had more value than required by the target mesh. It's very weird
July 24, 2021, 10:37 |
Rep Power: 14 |
From my limited experience with mapFields, I found that it was very important to have a correct, consistent initial set of files in the 0 time folder, to map onto. When I screwed up, with say an outdated swak4Foam list for the inlet with the wrong number of entries in the list for the mesh I was trying to map onto, I got a similar error message.
I wonder if you have a set of initial fields in your target case 0 folder that are for a model size of 4777920? This would explain why it is complaining that this does not match your mesh size of 212800, etc. Regardless - my advice is check carefully your 0 folder files in the target case. |
inconsistent, mapfields |
[SOWFA] NREL SOWFA ABLTerrainSolver tutorial problem | cico0815 | OpenFOAM Community Contributions | 36 | February 3, 2022 11:54 |
funkySetBoundaryFields - Manipulation of existing field | jhertel | OpenFOAM Pre-Processing | 16 | May 18, 2020 06:32 |
field read after each Time Step | johanning | OpenFOAM Programming & Development | 1 | December 29, 2019 07:59 |
Access to a field of a lagrangian post-processing cloudFunction | Ake | OpenFOAM Programming & Development | 0 | December 13, 2019 05:46 |
How to get cell indices and manipulate field data | ch1 | OpenFOAM Programming & Development | 5 | September 25, 2019 11:17 |
