Luis Sosa
Rep Power: 5 ![]() |
Hello Friends!
I come with a little doubt. I'm trying to simulate an axial flow compressor using a blade to blade passage. I impose mass flow at the inlet but I don't understand what does "value uniform (0 0 0)" mean. The axial direction of my domian is on the x-axis, so my Inlet patch is normal to the x-axis. Hope your help and thank you so much! |
Andreas P.
Rep Power: 9 ![]() |
The "value"-Entry is only a dummy, because boundary conditions are programmed in such a way that they need the "value"-Entry in every case.
So you can just ignore it in this case. Maybe the "value"-Entry is used in the first time-step as an initial condition, but this should not have big impact. Somebody please correct me if i'm wrong ![]() |
#3 | |
Luis Sosa
Thank you so much!!! So, if my mass flow is 64.15 kg/s I can set value uniform (0 0 0) without problem? |
Mark Olesen
Rep Power: 40 ![]() ![]() |
#flowrateinletvelocity, #openfoam |
Film cooling problem | arun1994 | OpenFOAM | 0 | October 26, 2020 09:08 |
rSF: p divergence in combustor (wt negative value) | zonda | OpenFOAM Pre-Processing | 4 | April 10, 2018 06:59 |
T Junction Stability | ignacio | OpenFOAM Running, Solving & CFD | 5 | May 2, 2013 10:44 |
[swak4Foam] Air Conditioned room groovyBC | Sebaj | OpenFOAM Community Contributions | 7 | October 31, 2012 14:16 |
Need help with boundary conditions: open to atmosphere | Wolle | OpenFOAM | 2 | April 11, 2011 07:32 |
