wmake libso - Error no Make directory
Old   June 24, 2021, 12:32
Unhappy wmake libso - Error no Make directory
troth
troth is on a distinguished road
Hello everyone,
Im trying to implement the patchMassFlowAverage function object following this instructions: http://http://openfoamwiki.net/index...unctionObjects.
When writing wmake libso I get the Error "no Make directory for /home/taniaroth/OpenFOAM/taniaroth-v2012" even I installed Make using: sudo apt-get install make (please see picture). Maybe Im in the wrong directory? Any idea what am I doing wrong?
Thank you very much
troth is offline   Reply With Quote
Old   June 28, 2021, 04:56
anonymous
simrego is on a distinguished road
Hi
What is in your directory? (use ll -s)
You need a Make directory since wmake make some "recipes" based on that folder (as the error tells you...) You need a "files" and "options" file inside that folder.
simrego is offline   Reply With Quote
error make directory, patchmassflowaverage, wmake libso
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 09:46
Changing Polynomial Properties of species from 8 to 16 coefficients Kenna OpenFOAM Programming & Development 1 November 20, 2013 04:44
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 05:43
OpenFoam install script Error during paraFoam installation SePe OpenFOAM Installation 10 June 19, 2010 16:15
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
