(Mac) ParaVew doesn't load OpenFOAM cases
Old   June 16, 2021, 09:02
Default (Mac) ParaVew doesn't load OpenFOAM cases
Anton Shevchenko
a.shevchenko is on a distinguished road
Hello everyone! I recently installed OpenFOAM and ParaView on my mac using docker, but PV in docker was running slow, so i installed it separately as a mac app.
To then open a case in PV I added an empty file with .foam extension into a case folder and it loaded successfully, I was able to work with my data... and then it just stopped working. I load .foam file into PV and nothing happens – no error messages, no nothing, it just sort of freezes. i tried googling an issue, reinstalling PV, rebooting, but nothing worked, so please, help!)
Thank you,
Anton.
a.shevchenko is offline   Reply With Quote
Old   June 17, 2021, 09:26
Default ParaView mac fixed...
Anton Shevchenko
Okay, okay. So i opened PV again today, and what I did was, I opened the app in fullscreen view (shift+cmd+f) – and it started working again...
Honestly not sure if that is what fixed the issue, but maybe it will help someone. Also try installing different versions of PV from their website (they have nightly versions, ARM versions for M1, etc.)
Regards, Anton.
Old   October 18, 2023, 10:59
Default paraview suggestion worked, but simulation animation is not in defined time limit.
Anand
Anand_j is on a distinguished road
Hey, thank you for the suggestion it works fine now with fullscreen and directly installed on mac rather than opening in docker, I have one trouble though, while running my simulation I get the end profiles but cannot get the animation can you help me with this ?
Anand_j is offline   Reply With Quote
mac, openfaom, paraview
[OpenFOAM.org] Install OpenFOAM 2.3.x on Mac OS gxuk OpenFOAM Installation 4 September 26, 2019 06:44
compile error when playing with OpenFOAM test cases TimLiu OpenFOAM Programming & Development 1 November 14, 2016 15:35
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker rt08 OpenFOAM Installation 1 February 28, 2016 20:00
running multiple parallel cases in openfoam slows the simulation kkpal OpenFOAM Running, Solving & CFD 2 August 21, 2015 12:08
Release load in OpenFOAM Maimouna OpenFOAM 4 November 5, 2013 07:38
