António Galhardo
Rep Power: 5 ![]() |
Hi everyone,
I am working on a problem with a fire in an enclosure, which i am modelling using firefoam. I have a question regarding which temperature boundary condition I should use at the wall, because it seems to me like OpenFOAM does not offer the right BC for this kind of situation. Heat transfer to the wall is significant and therefore an adiabatic BC is not adequate. Moreover, the effects of both convection and radiation need to be taken into account. The problem is transient, so the wall surface temperature will vary with time, as the wall will heat up due to the fire. As I understand it, the boundary condition to be applied at the wall surface should be an energy balance, meaning that the heat flux from the fire products should equal the heat flux inside the wall: ![]() Looking through the boundary conditions in OpenFOAM, the closest one I found was wallHeatTransfer, which calculates the wall temperature as: ![]() where ![]() ![]() ![]() This equation is therefore making an energy balance: the left-hand side has the convective flux from the fluid (with an "effective thermal conductivity", that takes into account the effects of turbulence), while the right-hand side expresses the conductive heat flux in the solid wall, by using a heat transfer coefficient called ![]() This BC does almost what I want, but there is something missing! It doesn't take into account the radiative heat flux. Therefore I compiled my own custom BC, simply adding the value of the radiative flux, as calculated by the radiation model: ![]() which can be rearranged as: ![]() However, when I tried to apply this BC I ran into some issues: although cells have realistic values of temperature, a few wall cells in the vicinity of the fire start showing very high and fast variations of both temperature and radiative heat flux. I plotted these variations and attached the results in figures to illustrate the issue. Therefore, I guess this isn't the ideal way to set up this BC. I'd be grateful if anyone could offer any ideas on how to tackle this problem differently. Has anyone had similar problems where you needed to apply this sort of BC? Do you see any problem with my approach that I should correct? Thanks in advance, António |
António Galhardo
Update:
I believe the problem has to do with the fact that the radiative heat flux depends on the wall temperature itself. Therefore, when the BC is calculated as I presented in my previous post, the value of ![]() ![]() ![]() The advantage here is that ![]() ![]() ![]() I would like to ask again if anyone can think of a different approach for this boundary condition. As said before, the problem is a compartment fire using fireFoam. The fire gases lose heat to the wall, so an adiabatic BC won't work. The wall heats up during the fire, so a fixed temperature BC won't work either. Which BC would you use instead, keeping in mind that the fluid loses heat to the wall due to both convection and radiation? Thanks in advance, António |
boundary condition, energy balance, firefoam, radiation, temparature |
Wall Temperature in Nozzle with RhoCentralFoam | Hillie | OpenFOAM Running, Solving & CFD | 1 | August 25, 2024 08:03 |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation | volleyHC | CFX | 5 | April 3, 2016 05:41 |
Radiation Modeling | Chris89 | CFX | 20 | August 14, 2014 07:51 |
