the inlet proile is not numbers while using funkySetFieldsDict |
June 1, 2021, 07:27 |
Hi guys,
I am using funkySetFields to set inlet profiles and initial fields. The following two scripts are regarding the 0_org/Ua and funkySetFieldsDict files, respectively. Code:
fields ( z Ua ); lookuptables ( { name inletprofilesedvel; outOfBounds clamp; file "$FOAM_CASE/1d_profil/Ua0.xy"; } { name inletprofilesedvelv; outOfBounds clamp; file "$FOAM_CASE/1d_profil/Ua2.xy"; Code:
inlet { type groovyBC; refValue uniform (0 0 0); valueExpression "vector(inletprofileua(pos().z),0,inletprofilewa(pos().z))"; gradientExpression "vector(0,0,0)"; fractionExpression "1"; evaluateDuringConstruction 1; variables ""; timelines ( ); lookuptables ( { name inletprofilewa; file "$FOAM_CASE/1d_profil/Ua1.xy"; outOfBounds clamp; Code:
( (-0.09976763165984251 2.254282019e-06) (-0.09930371004903199 6.748271668e-06) (-0.0988414157182435 1.1219279619e-05) (-0.0983807429595295 1.5667359493e-05) (-0.0979216860849635 2.0092638377e-05) (-0.09746423942657101 2.449525303e-05) (-0.0970083973362585 2.8875340809e-05) (-0.0965541541857445 3.3233038369e-05) (-0.09610150436648901 3.7568481483e-05) (-0.0956504422896245 4.1881805009e-05) (-0.0952009623858885 4.6173142888e-05) (-0.09475305910555301 5.0442628141e-05) (-0.09430672691835701 5.4690392869e-05) (-0.09386196031343699 5.8916568252e-05) (-0.09341875379926 6.3121284546e-05) (-0.092977101903556 6.7304671088e-05) (-0.0925369991732495 7.1466856289e-05) (-0.0920984401743925 7.5607967639e-05) (-0.091661419492097 7.9728131703e-05) (-0.0912259317304695 8.3827474123e-05) (-0.09079197151254301 8.7906119615e-05) (-0.090359533480211 9.1964191975e-05) (-0.08992861229416149 9.600181407e-05) (-0.089499202633811 0.000100019107847) (-0.089071299197239 0.000104016194326) Code:
Modifying field Ua of type volVectorField Putting "vector(inletprofilesedvel(pos().z),inletprofilesedvelv(pos().z),inletprofilesedvelw(pos().z))" into field Ua at t = "0" if condition "true" is true Keeping patches unaltered swak4Foam: Allocating new repository for sampledMeshes --> FOAM Warning : From function groovyBCFvPatchField<Type>::groovyBCFvPatchField(const fvPatch& p,const DimensionedField<Type, volMesh>& iF,const dictionary& dict) in file groovyBCFvPatchField.C at line 136 No value defined for Ua on inlet therefore using the internal field next to the patch Setting 5487152 of 5487152 cells Writing to "Ua" Code:
FoamFile { version 2.0; format binary; class volVectorField; arch "LSB;label=32;scalar=64"; location "0"; object Ua; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField nonuniform List<vector> 5487152 (�/P�4l�?^@^@^@^@^@^@^@^@1^C�bk�e��/P�4l�?^@^@^@^@^@^@^@^@1^C�bk�e��/P�4l�?^@^@^@^@^@^@^@^@1^C�bk�e��/P�4l�?$ ~�^M:�����Lyہˁ?^@^@^@^@^@^@^@^@^E~�^M:����сLyہˁ?^@^@^@^@^@^@^@^@^E~�^M:����сLyہˁ?^@^@^@^@^@^@^@^@^H~�^M:����$ ~�^M:�����Lyہˁ?^@^@^@^@^@^@^@^@ ~�^M:�����Lyہˁ?^@^@^@^@^@^@^@^@^H~�^M:����сLyہˁ?^@^@^@^@^@^@^@^@ 6�Ζ?^@^@^@^@^@^@^@^@*ʖx5�[��c� 6��?^@^@^@^@^@^@^@^@*�x5�[��c�� 6��?^@^@^@^@^@^@^@^@*�x5�[��c�� 6��?^@^@^@^@^@^@^@^@*�x5�[��c�� 6��?^@^@^@^@^@^@^@^@*�x5�[��c�� 6��?^@^@^@^@^@^@^@^@*�x5�[��c�� 6��?^@^@^@^@^@^@^@^@*�x5�[��c�� 6��?^@^@^@^@^@^@^@^@*�x5�[��c�� 6��?^@^@^@^@^@^@^@^@*�x5�[��c�� 6��?^@^@^@^@^@^@^@^@*�x5�[��c�� 6��?^@^@^@^@^@^@^@^@*�x5�[��c�� 6��?^@^@^@^@^@^@^@^@*�x5�[��c�� 6��?^@^@^@^@^@^@^@^@*�x5�[��c�� 6��?^@^@^@^@^@^@^@^@*�x5�[��c�� 6��?^@^@^@^@^@^@^@^@*�x5�[��c�� 6��?^@^@^@^@^@^@^@^@*�x5�[��c�� 6��?^@^@^@^@^@^@^@^@*�x5�[��c�� 6��?^@^@^@^@^@^@^@^@*�x5�[��c�� 6��?^@^@^@^@^@^@^@^@*�x5�[��c�� 6��?^@^@^@^@^@^@^@^@*�x5�[��c�� |
June 9, 2021, 07:35 |
Does anybody have an idea?
June 14, 2021, 13:05 |
This is related to the setting writeFormat in your controlDict. It looks like you have it as binary, so the computer can read it, but you probably can't. You could change it to ascii to check if the result is expected. However using binary actually saves some accuracy and disk space typically, so for the actual run I would advise to keep this as binary. If you want to keep the original file readable I suggest to make a copy of your 0 folder as 0.org before running funkySetFields. This will also help in correcting mistakes as you can quickly return to the original file. Have a look at some of the tutorials, they typically use this approach. Best Regards, Tom |
June 15, 2021, 09:39 |
#4 | |
funkysetfieldsdict, swak4faom |
setting the correct format of nonuniform List<vector> for inlet in 0 Folder | cfdonline2mohsen | OpenFOAM Running, Solving & CFD | 8 | July 18, 2019 09:03 |
Reversed flow using pressure inlet and outlet? | here_for_help | FLUENT | 0 | September 28, 2018 16:20 |
Adjuting oulet pressure till inlet pressure reaches a certain value in timestep | pvpnrao | OpenFOAM Running, Solving & CFD | 2 | September 11, 2018 11:14 |
velocity inlet and ideal gas simultaneously-what's wrong? | preetam69 | FLUENT | 0 | September 28, 2013 05:51 |
Inlet Velocity in CFX | aeroman | CFX | 12 | August 6, 2009 19:42 |
