Is it possible to give a wall temperature on a specific region?
Like Tree7Likes
Old   July 14, 2021, 11:33
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hi Amal,
If you only need to solve equations in a fluid domain, then buoyantSimpleFoam (steady solver) or buoyantPimpleFoam (transient solver) should do the job.
If you also need to solve the heat transfer in solids in addition to the fluid region(s), you should go for the chtMultiRegionFoam solver (Conjugate Heat Transfer).
If you are new to OpenFOAM and CFD, I strongly suggest to start reading the user guide and running tutorials in order to understand how OpenFOAM works before moving on to your own case. It is important to understand the basics before trying to work on your own cases. It can sound like a waste of time but I can guarantee you it could save you hours or days of struggle.
For the same reason, I would suggest to start heat transfer with the buoyantSimpleFoam solver before moving to CHT if required.
I hope this helps,
Yann
CHUMMAR likes this.
Yann is offline   Reply With Quote
boundary condition t, chtmultiregionfoam
Continuity Equation for multicomponent simulation lordluan CFX 15 May 19, 2020 19:36
A question related to writing expression for (htc)Heat transfer coefficient Hamda CFX 11 April 17, 2020 01:57
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
error message cuteapathy CFX 14 March 20, 2012 07:45
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
