FixedProfile polynomial Boundary Condition - Advice Please
Old   May 28, 2021, 01:09
Default FixedProfile polynomial Boundary Condition - Advice Please
John
basecase is on a distinguished road
Hi all - I'm an OpenFoam user but sadly, no coder
I currently use OpenFoam 7
I've used the fixedProfile inlet boundary condition with .csv files routinely without problem.
I am however stuck on the section in fixedProfileFvPatchField which refers to type as fixedProfile with profile assigned as - polynomial for the inlet BC.
I've researched fairly extensively and I apolgise if I missed a reference elsewhere that clarifies usage and might end my confusion. There are some references which refer to polynomials in profiles - but they don't seem to match my cases. The user guide alludes to polynomial functions in time dependent BCs - but those refs don't relieve my confusion.
I would be very grateful if some kind soul would explain in simple terms the numbers in the example quoted in fixedProfileFvPatchField documentation (below)-
inlet { type fixedProfile; profile polynomial ( ((1 0 0) (0 0 0)) ((-6200 0 0) (2 0 0)) ); direction (0 1 0); origin 0.0127; }
also U file from 0 folder for fully functioning pitzDaily version attached.
I have worked out some of the numbers - the max velocity of the function in the first set - and of course the direction and origin refs. I just can't quite get a handle on the remaining numbers - one looks like a coefficient for the profile function (in the above a parabola).
When I cut and paste the above into U in the 0 folder for pitzDaily the BC does indeed work well and deliver just what it says. Sadly that still hasn't brought enlightenment.
Attempts to plot the line function from the inlet (U @ t=0) in a spreadsheet have yielded little reward in terms of understanding - but a really nice parabola .
I have another less well defined question on this - the use of the term polynomial as in the attached (and above) implies the profile is flexible and not simply a parabolic profile function application. An understanding of the numbers will likely help me - but I would be grateful for any advice from those that have used this boundary condition to apply polynomials other than or in addition to parabolic functions as the inlet profile.
One last point - I'm not looking for alternative solutions to apply at this point - I'm on a mission of understanding that which I currently fail to grasp. And any advice of help would be very much appreciated.
Thanks
John Base
basecase is offline   Reply With Quote
boundary condition, fixedprofile, openfoam, polynomial bc
Cyclic boundary condition in foam-extend 4.0 rellumeister OpenFOAM Pre-Processing 2 March 3, 2020 09:03
Constant mass flow rate boundary condition sahm OpenFOAM 0 June 20, 2018 23:45
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
