Claudia
Rep Power: 5 ![]() |
Hey guys,
i m wondering how to calculate the turbulence intensity (for k-epsilon model) at the inlet. I have only found equations for pipes, but i have a rectangular, not a circular geometry. I think it should be a medium intensity, so something between 1 and 5% but i would like to have a equation for it. Does anyone have an idea? |
Herpes Free Engineer
Rep Power: 12 ![]() |
could help? initial conditions for k-epsilon model.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
Claudia
i have seen that webside, i want to use it to calculate k and epsilon but what I am looking for is way to calculate the turbulence intensity I.
To my knowledge, the magnitude of turbulence intensity is usually "set" by experimental values from similar laboratory or field experiments.
If such magnitude is not known, you simply "estimate" a value based on your engineering judgement and the case at hand. I don't think the turbulence intensity is a computable variable, like k, which you can find a closed-form expression for its estimation. Hope somebody else gives a better insight.
Rep Power: 14 ![]() |
Yes, agreed HPE. When you are asking "what value of turbulent intensity is appropriate?" then you are essentially asking "how turbulent is my flow?", and the answer is of course that it depends on the flow ... and how turbulent it is!
Outside of a boundary layer, you may have a very low intensity (eg. some wind tunnels work very hard to generate low free stream turbulence levels, <<1% intensity), i.e. close to laminar flow. inside a BL, or other shear layer, then values of the order of 5 to 15% are typical, although again this varies widely between flows and within flows (intensity varies across a BL, for example, peaking near the wall and decaying to the free stream value at the edge). The best idea, as HPE suggests, is to look in the literature for an analogous flow and see what values are present, then pick something appropriate. I would then suggest that you rerun your simulation with a smaller and a larger value, and check to see whether your results are sensitive to the parameter. |
Claudia
okay thank you both so much for your input! I will try to find values from similar experiments and then just estimate a value.
inlet condition, tubulence intesity, tubulence model |
calculate friction factor & nusselt number | soheil1991 | FLUENT | 3 | March 11, 2017 09:30 |
calculate velocity difference | helly | OpenFOAM Post-Processing | 0 | June 21, 2016 08:49 |
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel | nuimlabib | Main CFD Forum | 0 | August 4, 2009 00:05 |
How to calculate Torque for francis turbine | manish | CFX | 4 | March 15, 2007 02:57 |
Turbulence Intensity Vs CFD Simulation | Apple L S Chan | Main CFD Forum | 3 | December 15, 1998 17:28 |
