problem of using setExprFields
Old   May 24, 2021, 18:09
Exclamation problem of using setExprFields
kimy
qi.yang@polimi.it is on a distinguished road
Send a message via ICQ to qi.yang@polimi.it Send a message via AIM to qi.yang@polimi.it Send a message via Yahoo to qi.yang@polimi.it
Hi guys,
Due to the fact that swak4foam could not be installed on the cluster (most of the libraries were compiled but funkySetFields cannot be found), as shown in following:
/cineca/prod/opt/applications/openfoam+/v1912/intelmpi--2018--binary/OpenFOAM-v1912+/wmake/rules/linux64Gcc/c++:5: /cineca/prod/opt/applications/openfoam+/v1912/intelmpi--2018--binary/OpenFOAM-v1912+/wmake/rules/linux64Gcc/c++OptBDW: No such file or directory
make: *** No rule to make target `/cineca/prod/opt/applications/openfoam+/v1912/intelmpi--2018--binary/OpenFOAM-v1912+/wmake/rules/linux64Gcc/c++OptBDW'.  Stop.
wmake error: file 'Make/linux64IccDPInt32OptBDW/sourceFiles' could not be created in /galileo/home/userexternal/qyang001/OpenFOAM/qyang001-v1912/swak4Foam/Utilities/makeAxialMesh
In the user's lib, it includes already following src:
libEulerianInterfacialSedModels.so
libEulerianPpSedModels.so
libgranularRheologySedModel.so
libgroovyBC.so
libgroovyStandardBCs.so
libkineticTheorySedModel.so
libmyturbulenceModels.so
libsimpleCloudFunctionObjects.so
libsimpleFunctionObjects.so
libsimpleLagrangianFunctionObjects.so
libsimpleRegionSolvers.so
libsimpleSearchableSurfaces.so
libsimpleSwakFunctionObjects.so
libswak4FoamParsers.so
libswakChemistryModelFunctionPlugin.so
libswakCloudFunctionObjects.so
libswakCoalCloudAdaptor.so
libswakDynamicMeshFunctionPlugin.so
libswakDynamicMesh.so
libswakFacSchemesFunctionPlugin.so
libswakFiniteArea.so
libswakFunctionObjects.so
libswakFvcSchemesFunctionPlugin.so
libswakFvOptions.so
libswakGeneralLanguageIntegration.so
libswakLagrangianCloudSourcesFunctionPlugin.so
libswakLagrangianParser.so
libswakLocalCalculationsFunctionPlugin.so
libswakLuaIntegration.so
libswakMeshQualityFunctionPlugin.so
libswakMeshWaveFunctionPlugin.so
libswakMRFFunctionPlugin.so
libswakPython3Integration.so
libswakPythonIntegration.so
libswakQuantileFunctionPlugin.so
libswakRadiationModelFunctionPlugin.so
libswakRandomFunctionPlugin.so
libswakScriptableLagrangian.so
libswakShiftFieldFunctionPlugin.so
libswakSourceFields.so
libswakStateMachine.so
libswakSurfacesAndSetsFunctionPlugin.so
libswakThermoTurbFunctionPlugin.so
libswakTopoSources.so
libswakTransportTurbFunctionPlugin.so
libswakVelocityFunctionPlugin.so
libtwoPhaseModel.so
libtwoPhaseTurbulenceModels.so
Since I spent much time on this fact, I decided to use "setExprFields" which should be a similar function to funkySetFields. However, I failed to set that file. Could you please give me some suggestions regarding both issues?
The following scripts are only available for funkySetFieldsDict so how to transfer the right style into setExprFields. Thanks a lot.
expressions
	sedimentvelocity
	field Ua; //field to initialise
	fields
	z Ua
	lookuptables (
	name inletprofilesedvel;
	outOfBounds clamp;
	file "$FOAM_CASE/1d_profil/Ua0.xy";
	name inletprofilesedvelv;
	outOfBounds clamp;
	file "$FOAM_CASE/1d_profil/Ua2.xy";
	name inletprofilesedvelw;
	outOfBounds clamp;
	file "$FOAM_CASE/1d_profil/Ua1.xy";
        value uniform (1 0 0);
	expression "vector(inletprofilesedvel(pos().z),inletprofilesedvelv(pos().z),inletprofilesedvelw(pos().z))";
	keepPatches 1;
	fluidvelocity
	field Ub; //field to initialise
	fields
	z Ub
	lookuptables (
	name inletprofilefvel;
	outOfBounds clamp;
	file "$FOAM_CASE/1d_profil/Ub0.xy";
	name inletprofilefvelv;
	outOfBounds clamp;
	file "$FOAM_CASE/1d_profil/Ub2.xy";
	name inletprofilefvelw;
	outOfBounds clamp;
	file "$FOAM_CASE/1d_profil/Ub1.xy";
	expression "vector(inletprofilefvel(pos().z),inletprofilefvelv(pos().z),inletprofilefvelw(pos().z))";
	keepPatches 1;
       alpha
        field alpha_a; //field to initialise
        fields
        z alpha
        lookuptables (
        name inletprofilealpha;
        outOfBounds clamp;
        file "$FOAM_CASE/1d_profil/alpha_a.xy";
        expression "inletprofilealpha(pos().z)";
        keepPatches 1;
      pb
        field p_rbgh; //field to initialise
        fields
        z p_rbgh
        lookuptables (
        name inletprofilepb;
        outOfBounds clamp;
        file "$FOAM_CASE/1d_profil/p_rbgh.xy";
        expression "inletprofilepb(pos().z)-3.998*(pos().x-0.8)";
        keepPatches 1;
       k
        field k; //field to initialise
        fields
        z k
        lookuptables (
        name inletprofilek;
        outOfBounds clamp;
        file "$FOAM_CASE/1d_profil/k.xy";
        expression "inletprofilek(pos().z)";
        keepPatches 1;
       omega
        field omega; //field to initialise
        fields
        z omega
        lookuptables (
        name inletprofileomega;
        outOfBounds clamp;
        file "$FOAM_CASE/1d_profil/omega.xy";
        expression "inletprofileomega(pos().z)";
        keepPatches 1;
qi.yang@polimi.it is offline   Reply With Quote
Old   May 25, 2021, 16:15
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
A good-quality documentation about "expressions" can be found here.
Hope this helps for your code transformation.
HPE is offline   Reply With Quote
setexprfields, swak4foam
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
