inlet boundary conditions inside domain
Old   May 10, 2021, 23:44
Default inlet boundary conditions inside domain
yan
yxl1453 is on a distinguished road
Hi, I was running a simulation of a burner in the center of the domain.
The burner was extruded with two patches. The goal is to set a fuel inlet boundary condition on the bottom patch side. For the burner, the top patch velocity is set to zero, and the bottom patch is set with "flowRateInletVelocity" with a positive mass flow rate.
To my surprise, in the results, although most combustion occurs on the bottom patch side which is reasonable, some of the combustions indeed occur below the burner (on the top patch side). Since I was trying to set the top patch as a wall, it is not reasonable to see fuel on this side
So I am wondering if the "flowRateInletVelocity" allows flow across it? And anyone could help and suggest a reasonable boundary condition for the burner
yxl1453 is offline   Reply With Quote
inlet boundary condition, wall boundary condition
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Turbomachinery Mass imbalance sheaker CFX 12 September 5, 2019 09:09
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Low torque values on Screw Turbine Shaun Waters CFX 34 July 23, 2015 09:16
