timeVaryingMappedFixedValue not Updated with refineMesh (v2006)
Old   May 10, 2021, 10:32
Unhappy timeVaryingMappedFixedValue not Updated with refineMesh (v2006)
CoolHand is on a distinguished road
Foamers,
My case is a large mesh (~450e6) which causes blockMesh to fail (bad number). I got around that problem by starting with a coarse mesh and using refineMesh -parallel after decomposePar. I'm using timeVaryingMappedFixedValue at the inlet and when I got to run pisoFoam I get an error like this:
[3357]--> FOAM FATAL IO ERROR:
[3357] size 501 is not equal to the given value of 2004
[3357]
[3357] ... /processor3357/0/U.boundaryField.inlet at line 58 to 60.
[3357]     From Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = Foam::Vector<double>; Foam::label = int]
[3357]     in file [3202]
...for each processor on the inlet. The numbers are different for each processor since I'm using scotch decomposition but they're always 1/4 ratio so clearly the problem is that the assignment that timeVaryingMappedFixedValue gets from blockMesh isn't updated by refineMesh.
I've tried several combinations like:
decomposePar
refineMesh
decomposePar -fields
decomposePar
refineMesh
decomposePar -copyZero
decomposePar -noZero
refineMesh
I've also tried
decomposePar
refineMesh
reconstructPar
...but reconstructPar gives a similar error. So far nothing has worked. Is there another tool or option that can update the decomposed inlet BCs to match the refinedMesh? I would also accept advice on how to get blockMesh to do the large mesh in the first place, although I'm skeptical that there is such a way since I'm running it on a large memory cluster node and it still fails. Thanks!
CoolHand is offline   Reply With Quote
decomposepar, mappedfixedvalue, refinemesh, timevarying
OpenFOAMŪ v2006: New and updated solvers and physics OPFO OpenFOAM Programming & Development 0 August 28, 2020 07:57
[OpenFOAM.com] complile v2006 with runTimePostProcessing functionality snak OpenFOAM Installation 2 August 1, 2020 09:08
[mesh manipulation] multiple calls to refineMesh parallel w/ dict failing Regis_ OpenFOAM Meshing & Mesh Conversion 2 June 4, 2015 14:44
[mesh manipulation] checkMesh Erros after refineMesh mgdenno OpenFOAM Meshing & Mesh Conversion 10 October 14, 2014 06:16
[mesh manipulation] Cannot get refineMesh to run in parallel smschnob OpenFOAM Meshing & Mesh Conversion 2 June 3, 2014 12:20
