May 7, 2021, 10:05 |
Bubble formation from orifice with interfoam
Bushra Rasheed
Rep Power: 5 |
Hi!
I am trying to simulate an air bubble formed from a 1mm orifice. But I am getting very unrealistic results. I have defined an inletOutlet boundary condition at outlet in velocity and fixedFluxPressure at outlet in p_rgh. The side walls are slip walls. Contact angle is set at 25 degrees. The 1mm orifice is not defined in setFields, rather it is set as fixedValue boundary condition of uniform 0 in alpha.water. Outlet is also set at fixedValue 0 in alpha.water. I have also tried using inletOutlet instead of fixedValue. I have tried using constant flow rate boundary condition at orifice as well but still the results are very unrealistic. The air at outlet should not be moving neither should the bubble shape distort so much. No bubbles are formed if I give 0 orifice velocity or very small flow rate in the boundary condition. Attaching pictures of initial setfields domain and bubbles formed at 2 different time steps. Please help! |
contact angle, interfoam bubble, multiphase |
Getting a concentration field around a bubble in InterFoam | azman | OpenFOAM Running, Solving & CFD | 3 | June 7, 2022 05:21 |
Bubble formation in microfluidics | MuhammadAliDurrani | Fluent Multiphase | 0 | December 18, 2020 15:01 |
Rising bubble with interFoam | tayo | OpenFOAM Running, Solving & CFD | 16 | March 12, 2020 13:11 |
How to model bubble formation in a vapour line of a loop heat pipe | jayxavier77 | Fluent Multiphase | 6 | August 15, 2015 19:48 |
Flow boiling & bubble formation | Venkat | CFX | 1 | July 23, 2009 10:20 |
