Help with tutorial 12 SnappyHexMesh OpenFOAM® Basic Training
Old   April 29, 2021, 23:30
Post Help with tutorial 12 SnappyHexMesh OpenFOAM® Basic Training
edgar africano
Edafri is on a distinguished road
Hi. I have been trying to do the tutorial 12 (https://www.cfd.at/sites/default/fil...rialSeries.pdf) which is about SnappyHexMesh and running a simulation with this mesh. Running the simulation, the following error appaers:
-> FOAM FATAL IO ERROR: (openfoam-2012)
"ill defined primitiveEntry starting at keyword 'internalField' on line 20 and ending at line 12278"
file: /home/xxxxxxx/OpenFOAM/OpenFOAM-v2012/tutorials/basic/scalarTransportFoam/pitzDaily2/0/U at line 12278.
From void Foam:rimitiveEntry::readEntry(const Foam::dictionary&, Foam::Istream&)
in file db/dictionary/primitiveEntry/primitiveEntryIO.C at line 236.
The tutorial says the following to modify the U file:
- Update the U file in the 0 directory so that the velocity in the entire flange domain and at the boundaries is zero.
I modify the U file like this:
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "288";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField nonuniform List<vector>
12225
(9.85698 -0.886449 0)
(9.66665 -0.740747 0)
(9.45574 -0.429483 0)
(9.22457 -0.222216 0)
(9.00656 -0.106462 0)
it keeps going.........
boundaryField
flange_patch1
type fixedValue;
value uniform (0 0 0);
flange_patch2
type fixedValue;
flange_patch3
type fixedValue;
flange_patch4
type fixedValue;
I am very new to OpenFOAM and I am not sure why it is the error source. I kindly ask to the community where it could be the mistake. Thank you
Edafri is offline   Reply With Quote
Old   April 30, 2021, 04:47
Max
Dikkeunit is on a distinguished road
Hey,
just a quick look from me. I am not sure if there is an issue in the List but I did see that you are missing a ; after the internalFields, which may give the issue.
12225
Dikkeunit is offline   Reply With Quote
openfoam 2012, simulation won't run, snappyhexmesh, tutorial 12
Meshing using snappyhexmesh flange tutorial. shahidkhan OpenFOAM 7 January 20, 2020 05:04
OpenFOAM introductory training. Jul 16-20, 2018. Uni. Genova, Italy - Wolfdynamics joegi.geo OpenFOAM Announcements from Other Sources 0 April 26, 2018 11:35
2nd OpenFOAM® Training in Brazil - Sao Jose dos Campos mjsdelemos OpenFOAM Announcements from Other Sources 7 August 17, 2011 08:37
OpenFOAM® Training in Brazil - Sao Jose dos Campos mjsdelemos OpenFOAM Announcements from Other Sources 0 September 21, 2010 07:59
CFX basic training for a non-beginner zebG CFX 3 December 22, 2009 04:16
