Erol Bicer
Rep Power: 5 ![]() |
Hello, everyone!
I was looking at the differences between laminar and turbulent modeling of a case (multiphaseEulerFoam > RAS > bubbleColumn) and I realized that one of the divergence scheme is different for laminar and RAS case. Is this a typo or am I missing something? Code:
"div\(\(\(\(alpha.*\*thermo:rho.*\)\*nuEff.*\)\*dev2\(T\(grad\(U.*\)\)\)\)\)" Gauss linear; Code:
"div\(\(\(\(alpha.*\*thermo:rho.*\)*nuEff.*\)\*dev2\(T\(grad\(U.*\)\)\)\)\)" Gauss linear; The difference is " )\*nuEff. " parts of both lines. The laminar case has \ but RAS is missing it. Thank you in advance, Erol. |
laminar, multiphaseeulerfaom, ras, twophaseflow |
Low Re Turbulence model VS Low Re flow and Turbulence Modelling background | pchoopanya | Main CFD Forum | 4 | May 10, 2018 11:05 |
Y+ in k epsilon model for bubble column | ROY4 | CFX | 3 | March 14, 2018 13:50 |
How to measure gas holdup in bubble column | sunilsah2011 | Fluent Multiphase | 0 | January 28, 2018 06:37 |
Bubble Column Simulation: Different Turbulence Models different results | zobekenobe | CFX | 5 | January 28, 2013 09:02 |
Help required for CFD simulation of Trayed Bubble Column using Fluent | art705 | Main CFD Forum | 0 | July 15, 2009 04:04 |
