fixing volume fraction at a certain region
Old   April 14, 2021, 17:45
Default fixing volume fraction at a certain region
fredrick
fredrick is on a distinguished road
Greetings
I would like to fix volume fraction of air at 1 (and hence zero for solid particles) during the simulation in a region defined as fluid-part-lower as seen in the code below. My thinking is that i should fix particle velocity at zero in this region and alpha.air and alpha.particles at 1 and 0 respectively. This is however not working. could anyone help me correct the problem
fixedVelocity
type vectorFixedValueConstraint;
selectionMode cellZone;
cellZone fluid-part-lower;
fieldValues
U.particles (0 0 0);
volumeFraction
type scalarFixedValueConstraint;
fieldValues
alphar.particles 0;
alphar.air 1;
fredrick is offline   Reply With Quote
fluidized bed, openfoam
multiphaseEulerFoam high Courant number Frenk_T OpenFOAM 5 November 24, 2016 04:23
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel Mehrez OpenFOAM Running, Solving & CFD 10 May 18, 2016 12:44
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
