lastestTime step does not start the computation from latest time step
Old   April 13, 2021, 14:06
Default lastestTime step does not start the computation from latest time step
Deutschland
vava10 is on a distinguished road
Dear fomers,
I ran a ship simulation to determine the trim and sinkage of the ship using HPC.
I ran the simulation for 5 sec and I used latestTime to continue the simulation from the lastest time it computed for the first set of computation.
below shows the force.data files from
1. 0 time folder last steps
2.76528       	(-4.455511e+01 -2.227696e+02 3.752130e+02)	(-6.917687e+00 -2.231236e+02 3.756478e+02)	(-3.763743e+01 3.540872e-01 -4.347268e-01)
2.7655        	(-4.455581e+01 -2.228436e+02 3.751877e+02)	(-6.917884e+00 -2.231978e+02 3.756223e+02)	(-3.763793e+01 3.542508e-01 -4.346274e-01)
2.7657        	(-4.456513e+01 -2.227126e+02 3.751850e+02)	(-6.926742e+00 -2.230670e+02 3.756195e+02)	(-3.763839e+01 3.543987e-01 -4.344901e-01)
2.76589       	(-4.456057e+01 -2.228834e+02 3.751834e+02)	(-6.921693e+00 -2.232379e+02 3.756177e+02)	(-3.763887e+01 3.545719e-01 -4.343035e-01)
2.7661        	(-4.457611e+01 -2.224234e+02 3.751889e+02)	(-6.936709e+00 -2.227781e+02 3.756230e+02)	(-3.763940e+01 3.547871e-01 -4.340681e-01)
2.76631       	(-4.458474e+01 -2.228396e+02 3.751992e+02)	(-6.944764e+00 -2.231946e+02 3.756329e+02)	(-3.763997e+01 3.550535e-01 -4.337818e-01)
2.76653       	(-4.459933e+01 -2.226026e+02 3.752060e+02)	(-6.958776e+00 -2.229580e+02 3.756395e+02)	(-3.764055e+01 3.553498e-01 -4.334493e-01)
2.76676       	(-4.457807e+01 -2.231264e+02 3.752116e+02)	(-6.936974e+00 -2.234821e+02 3.756447e+02)	(-3.764110e+01 3.556705e-01 -4.330993e-01)
2.76699       	(-4.457654e+01 -2.225572e+02 3.752087e+02)	(-6.935022e+00 -2.229132e+02 3.756415e+02)	(-3.764152e+01 3.559475e-01 -4.328142e-01)
2.76723       	(-4.456011e+01 -2.229260e+02 3.752073e+02)	(-6.918301e+00 -2.232821e+02 3.756399e+02)	(-3.764181e+01 3.561587e-01 -4.326462e-01)
2.76746       	(-4.455977e+01 -2.222491e+02 3.752042e+02)	(-6.917780e+00 -2.226054e+02 3.756367e+02)	(-3.764199e+01 3.563131e-01 -4.325497e-01)
2.7677        	(-4.455221e+01 -2.227564e+02 3.752158e+02)	(-6.910141e+00 -2.231129e+02 3.756483e+02)	(-3.764207e+01 3.564174e-01 -4.324983e-01)
2.76793       	(-4.455185e+01 -2.222399e+02 3.752280e+02)	(-6.909761e+00 -2.225964e+02 3.756605e+02)	(-3.764209e+01 3.564870e-01 -4.324721e-01)
2.76816       	(-4.454115e+01 -2.227310e+02 3.752047e+02)	(-6.899051e+00 -2.230875e+02 3.756372e+02)	(-3.764210e+01 3.565338e-01 -4.324750e-01)
2.7684        	(-4.453818e+01 -2.222074e+02 3.752168e+02)	(-6.896153e+00 -2.225639e+02 3.756493e+02)	(-3.764203e+01 3.565550e-01 -4.325041e-01)
2.76863       	(-4.452816e+01 -2.225971e+02 3.752127e+02)	(-6.886234e+00 -2.229536e+02 3.756452e+02)	(-3.764192e+01 3.565648e-01 -4.325413e-01)
2.76887       	(-4.453365e+01 -2.222775e+02 3.752104e+02)	(-6.891833e+00 -2.226340e+02 3.756430e+02)	(-3.764182e+01 3.565711e-01 -4.325820e-01)
and the first step in the next time folder 2
2.00024       	(-4.400534e+01 -2.048696e+02 3.411866e+02)	(-6.441071e+00 -2.052133e+02 3.416641e+02)	(-3.756427e+01 3.437174e-01 -4.774407e-01)
2.00047       	(-4.443299e+01 -2.393942e+02 4.002413e+02)	(-6.869032e+00 -2.397392e+02 4.007149e+02)	(-3.756395e+01 3.449284e-01 -4.736160e-01)
2.00071       	(-4.417676e+01 -2.179741e+02 3.639568e+02)	(-6.612592e+00 -2.183190e+02 3.644308e+02)	(-3.756417e+01 3.448740e-01 -4.739724e-01)
2.00095       	(-4.413977e+01 -2.162516e+02 3.602697e+02)	(-6.575413e+00 -2.165963e+02 3.607444e+02)	(-3.756436e+01 3.446434e-01 -4.746962e-01)
2.00119       	(-4.416509e+01 -2.187782e+02 3.654427e+02)	(-6.600500e+00 -2.191228e+02 3.659175e+02)	(-3.756459e+01 3.445994e-01 -4.748181e-01)
2.00142       	(-4.419644e+01 -2.209400e+02 3.683273e+02)	(-6.631610e+00 -2.212847e+02 3.688019e+02)	(-3.756483e+01 3.446670e-01 -4.746333e-01)
2.00166       	(-4.418820e+01 -2.198558e+02 3.673266e+02)	(-6.623141e+00 -2.202005e+02 3.678012e+02)	(-3.756506e+01 3.447038e-01 -4.745716e-01)
2.0019        	(-4.418621e+01 -2.197569e+02 3.663669e+02)	(-6.620928e+00 -2.201016e+02 3.668415e+02)	(-3.756528e+01 3.447018e-01 -4.746228e-01)
2.00214       	(-4.417974e+01 -2.193759e+02 3.664518e+02)	(-6.614252e+00 -2.197206e+02 3.669265e+02)	(-3.756549e+01 3.447032e-01 -4.746684e-01)
2.00237       	(-4.418637e+01 -2.199264e+02 3.667299e+02)	(-6.620669e+00 -2.202711e+02 3.672045e+02)	(-3.756571e+01 3.447202e-01 -4.746881e-01)
2.00261       	(-4.418081e+01 -2.195276e+02 3.667757e+02)	(-6.614928e+00 -2.198724e+02 3.672504e+02)	(-3.756589e+01 3.447339e-01 -4.747141e-01)
As you can see the latest time in the 0 time folder was 2.76887 but in the time folder 2, the first time step is 2.00024
As a result, the results of k look as the image attached
Can anyone tell me the reason for this error?
Kind regards
vava10
vava10 is offline   Reply With Quote
Old   April 13, 2021, 16:44
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
I think the `latestTime` entry uses the latest available time directory of fields - not the latest time entry in the text file output by the forces function object. For the latter, you need to use some scripting or manual manipulation to remove the same time-step data.
Hope this helps.
HPE is offline   Reply With Quote
controldict, openfoam, post procesing, timestep
Time Step Continuity Errors simpleFoam Dorian1504 OpenFOAM Running, Solving & CFD 1 October 9, 2022 10:23
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? EternalSeekerX SU2 3 October 9, 2020 19:28
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 08:56
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
