Can we initialize weakly compressible solver with potentialFoam ?
Old   April 13, 2021, 10:39
Default Can we initialize weakly compressible solver with potentialFoam ?
Kermit
tyskies is on a distinguished road
Hello everyone !!
I'm currently trying to simulate the flow around a cylinder (Re=3900) in order to extract the acoustic fields. To do so I'm using the rhoPimpleAdiabaticFoam (weakly compressible solver) solver which is particularly efficient for low Mach number flows.
I'd like to know if we can use potentialFoam to initialize U and P ? Note that the 0/ folder contains all those paramaters files: alphaT, k, epsilon, nut, p, T, U.
Thanks!
Tyskies
tyskies is offline   Reply With Quote
Old   April 14, 2021, 13:29
thanat
thanat is on a distinguished road
Hi, How can you get the result of acoustic? Did you get them ex SPL
thanat is offline   Reply With Quote
Old   April 14, 2021, 13:46
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
potentialFoam is only for incompressible flows, as far as I know. for compressible flows, you will need to implement your code, I'm afraid OR you can only use velocity field produced by potentialFoam.
HPE is offline   Reply With Quote
DES, DDES, IDDES for compressible solver rhoCentralFoam eddykendo OpenFOAM Running, Solving & CFD 3 February 22, 2022 05:04
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 06:02
Compressible Solver Implementation in FSI Library (Foam-extend 3.2) KarthickRajkumar OpenFOAM Programming & Development 1 January 4, 2017 07:45
Difference between Compressible CFD solver and Incompressible CFD solver arijith Main CFD Forum 6 September 23, 2012 20:23
Liquid instead of gas in a compressible solver !? iggor OpenFOAM 15 October 14, 2009 12:58
