manual decomposition
Old   February 23, 2021, 17:55
Default manual decomposition
Marcelo Italo Adotti
italoadotti is on a distinguished road
Hi everybody,
I tried decompose manually my domain (with overset patches) with this tutorial.
Manual decomposition using setFields
It works perfect in a single mesh, but i have some problems with zones of overset interpolations.
The command decomposePar -cellDist output this warning error:
--> FOAM Warning :
From void Foam:versetFvPatchField<Type>::initEvaluate(Foam ::UPstream::commsTypes) [with Type = double]
in file oversetPolyPatch/oversetFvPatchField.C at line 125
Reading "/home/italoadotti/OpenFOAM/italoadotti-v2006/run/foil_shmmesh_manual/backGround/system/fvSchemes"
Missing required dictionary entry 'oversetInterpolation'. Skipping overset interpolation for field cellDist
Some idea or solution?
Regards, Marcelo
italoadotti is offline   Reply With Quote
Old   February 26, 2021, 08:29
anonymous
simrego is on a distinguished road
Hi!
Just read the error. It is clear:
1st line: It is reading the system/fvSchemes file
2nd line: it cannot find the 'oversetInterpolation' entry.
It is always recommended to create your own case from a tutorial if you don't know how to use the specific solver. Just open up an overset tutorial and check this entry in any of them.
simrego is offline   Reply With Quote
Old   June 16, 2023, 19:15
Mohamed Shabara
Mohamed Shabara is on a distinguished road
Mocking his question is not a good approach; this warning happens with overSet mesh even if the "oversetInterpolation" is defined in the system/fvSchemes.
Mohamed Shabara is offline   Reply With Quote
celldist, decomposepar, oversetinterpolation
Manual decomposition using setFields RL-S OpenFOAM Pre-Processing 8 July 3, 2023 09:51
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 15:07
Manual Decomposition Method smraniaki OpenFOAM Pre-Processing 3 November 24, 2013 17:53
Manual decomposition of domain pss OpenFOAM Pre-Processing 0 April 26, 2012 02:33
Description file for manual decomposition A.Devesa OpenFOAM Running, Solving & CFD 2 July 4, 2011 09:09
