interpolating 1D data to a 2D inlet patch
Old   February 2, 2021, 23:53
Default interpolating 1D data to a 2D inlet patch
Anonymous
backscatter is on a distinguished road
Let's say I have a 1D Blasius profile that I want to prescribe as an inlet bc on a flat plate. Is there any way in FOAM to easily map this 1D profile to the 2D inlet patch?
Thanks,
backscatter is offline   Reply With Quote
Old   February 10, 2021, 11:53
Agustín Villa
agustinvo is on a distinguished road
Hi backscatter
when using this klind of profiles you need to specify values for all the patch points (not cells). It is enough with replicating your inlet profile twice. I reccomend you to find in the OF tutorials a case that you can use for your purpose.
Cheers
agustinvo is offline   Reply With Quote
Old   February 10, 2021, 15:12
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
You can apply agustinvo's suggestion with `timeVaryingMappedFixedValue` boundary condition, I think.
HPE is offline   Reply With Quote
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 21:00
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times vidyadhar ParaView 9 May 20, 2020 20:06
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 07:30
[blockMesh] Cyclic BC's: Possible face ordering problem? (Channel flow) sega OpenFOAM Meshing & Mesh Conversion 3 September 28, 2010 12:46
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
