January 14, 2021, 15:03 |
Transient simulation over NACA0015
Albert
Rep Power: 6 |
Hello friends,
I am new on OpenFOAM and want to simulate a transient flow over a NACA0015 using pisoFoam solver. I want to emmulate a sinusoidal velocity at bc "jet" but I don't know if it is well defined. Apart I get an error from openfoam: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2006 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _b45f8f6f58-20200629 OPENFOAM=2006 Arch : "LSB;label=32;scalar=64" Exec : pisoFoam Date : Jan 14 2021 Time : 20:56:05 Host : LAPTOP-KI5PL9IT PID : 649 I/O : uncollated Case : /home/agrande/OpenFOAM/OpenFOAM-v2006/run/muestra1 nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PISO: Operating solver in PISO mode Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model SpalartAllmaras --> FOAM FATAL IO ERROR: Entry 'method' not found in dictionary "/home/agrande/OpenFOAM/OpenFOAM-v2006/run/muestra1/system/fvSchemes.wallDist" file: /home/agrande/OpenFOAM/OpenFOAM-v2006/run/muestra1/system/fvSchemes.wallDist From bool Foam::dictionary::readEntry(const Foam::word&, T&, Foam::keyType:ption, bool) const [with T = Foam::word] in file /home/pawan/OpenFOAM/OpenFOAM-v2006/src/OpenFOAM/lnInclude/dictionaryTemplates.C at line 334. FOAM exiting I don't know which is the error I am doing neither if the jet velocity is well defined. |
January 14, 2021, 15:08 |
Albert
Rep Power: 6 |
January 15, 2021, 16:39 |
Herpes Free Engineer
Rep Power: 13 |
I would also start with a steady-state approach (i.e. simpleFoam) before diving into the transient case.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
active flow control, cfd, sinusoidal, transient bc |
Continuing transient simulation after steady simulation | billy7590 | FLUENT | 0 | September 19, 2017 08:56 |
Transient RANS Simulation | Bazinga | Main CFD Forum | 5 | June 21, 2017 11:21 |
Transient simulation diverges | Graduation | ANSYS | 0 | February 28, 2012 07:13 |
How to integrate variable in a transient simulation? | nprace | CFX | 4 | January 9, 2012 08:59 |
Beginning a Transient Simulation | Norflow | CFX | 2 | October 7, 2011 00:38 |
