blockMesh problem when grading applied with cyclic patch
Old   January 3, 2021, 05:54
Default blockMesh problem when grading applied with cyclic patch
Henrik
broccolibadger is on a distinguished road
blockMesh with grading works like a charm without grading as per attached images A & B.
With grading specified and changing cyclic to wall, the mesh is generated beautifully. Problem starts when cyclic and grading is combined, see image C.
blockMeshDict is attached.
Gradings:
gz0 1;
gz1 1;
gr 1;
gz0 .1;
gz1
    (.3 3 1)
    (.7 2 5)
gr 10;
Patch specifications:
cyclicA
        type            cyclic;
        neighbourPatch  cyclicB;
        transform       rotational;
        rotationAxis    (0 0 1);
        rotationCentre  (0 0 0);
//        rotationAngle   270;
        matchTolerance  1e-5;
        faces
                (7 32 29 0)
                (32 10 3 29)
                (10 12 5 3)
                (10 17 19 12)
                (17 24 26 19)
                (35 38 24 17)
                (14 21 38 35)
    cyclicB
        type            cyclic;
        neighbourPatch  cyclicA;
//        rotationAngle   90;
        faces
                (0 28 31 7)
                (28 1 8 31)
                (1 2 9 8)
                (9 16 15 8)
                (15 16 23 22)
                (22 37 15 34)
                (34 37 21 14)
Error message:
cyclicPolyPatch::calcTransforms : Writing cyclicA faces to OBJ file "cyclicA_faces.obj"
cyclicPolyPatch::calcTransforms : Writing cyclicB faces to OBJ file "cyclicB_faces.obj"
cyclicPolyPatch::calcTransforms : Writing coupled face centres as lines to "cyclicA_to_cyclicB.obj"
--> FOAM FATAL ERROR:
face 1 area does not match neighbour by 25.44563% -- possible face ordering problem.
patch:cyclicA my area:4.1126e-05 neighbour area:3.184237e-05 matching tolerance:1e-05
Mesh face:6011 fc:(0 0.002292 0.01345746)
Neighbour fc:(0.000764 0 0.03733454)
If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file.
Rerun with cyclic debug flag set for more information.
    From void Foam::cyclicPolyPatch::calcTransforms(const primitivePatch&, const pointField&, const vectorField&, const pointField&, const vectorField&)
    in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 215.
FOAM exiting
I'm using .com-version v2006
To me this looks like a bug in how cyclic is implemented. I can't seem to find any other reason for this not to work.
broccolibadger is offline   Reply With Quote
openfoam ext4.0 and problem in cyclic condition Hgholami OpenFOAM Pre-Processing 2 February 19, 2019 11:53
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 02:47
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 03:01
Problem in defining patch deformation paul b OpenFOAM Programming & Development 3 April 27, 2010 01:31
