How to select a mesh generated from an .stl file? |
December 13, 2020, 23:50 |
Homer Bacanto
Rep Power: 5 |
Hello FOAMers!
I'm trying to change the physical properties of a wall into that of cement, but I'm not exactly sure how. I'm reading a wall in the form of an .STL file using surfaceFeatures, building the mesh with blockMesh, and then trimming it to the proper shape using snappyHexMesh. I want to change the physical properties of the wall read from the .STL file, probably using setFields, but I'm not sure how to go about it. I guess I could use something like box to cell, but I was looking to be able to do it without manually figuring out the dimensions of the wall from the STL file. Any help would be appreciated. Thanks! |
openfoam 7, setfields |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 02:41 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 14:59 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
