Merging Paths using BlockMesh
Old   December 5, 2020, 21:41
Default Merging Paths using BlockMesh
Matheus
Matheus.Costa is on a distinguished road
Hello there, I'm trying to make an orifice plate geometry using blockMesh, so I used the arc function to create 3 cylinders stacked but now I have a doubt, each cylinder was created using 5 blocks and all of them have a inlet and outlet, but I can't figure out how to merge them in a way that results in one inlet and outlet, I also don't know how to set the initial condition once two paths are merged and would be very thankful if any of you guys could help me out.
I attached the blockMeshDict file and an image of the whole geometry.
Matheus.Costa is offline   Reply With Quote
blockmesh, meshing, opeanfoam, orifice plate
[blockMesh] blockMesh: merging two unmatching faces pbe_cfd OpenFOAM Meshing & Mesh Conversion 7 December 10, 2019 06:38
[blockMesh] blockMesh multiple merging on same hex krzychu111 OpenFOAM Meshing & Mesh Conversion 1 December 20, 2018 01:03
[blockMesh] blockMesh merging ancolli OpenFOAM Meshing & Mesh Conversion 4 May 13, 2016 19:11
[blockMesh] block merging with blockMesh vaina74 OpenFOAM Meshing & Mesh Conversion 0 October 21, 2014 04:16
[blockMesh] BlockMesh face merging duderino OpenFOAM Meshing & Mesh Conversion 12 June 23, 2010 06:56
