Initialization of compressible flows
Old   November 29, 2020, 17:16
Post Initialization of compressible flows
Numbers is on a distinguished road
Good evening everyone,
I am working on a compressible unsteady flow case that is conceptually similar to a flow inside a duct containing a bluff body and would like to know if there is a smart way to initialize the flow.
I know that unsteady simulation are such because the unknown is generally the response to some external forcing, but in this situation I just need a reasonable representation of what is going on behind the bluff body ( Von Karman vortex - which is intrinsically unsteady) and I do not really care how the system reaches the final state (which is unsteady but hopefully periodic).
If it were incompressible I would use potentialFoam, and then run rhoPimpleFoam but this procedure gives me an error (obviously since in the first the pressure is a sort of Lagrangian multiplier whereas in the latter it is actually a pressure and has different dimensions). Is there a way to initialize at least the U field by potentialFoam? How to do it?
I thought of mapFields utility too, that is reasonable if I had a previous simulation of the same kind which I have not (I have just the incompressible equivalent which suffers the same problem of the output of laplacianFoam).
Thanks in advance.
Numbers is offline   Reply With Quote
bluff bodies, initialization method, potentialfoam, von karman vortex
Capability of Fluent to model compressible flows Hamid-Moezzi FLUENT 6 October 29, 2018 08:36
About LES model for compressible flows Eric Brant OpenFOAM Pre-Processing 1 March 30, 2015 08:58
Why is the side slip option only for compressible flows denzell SU2 1 March 10, 2015 20:26
what can say about separation modeling of compressible flows in OF? immortality OpenFOAM Running, Solving & CFD 0 May 5, 2013 22:36
Using pressure based solver for compressible flows aamer Main CFD Forum 2 June 15, 2011 13:45
