Coupling Two Fluid Regions Differently to Solve Heat Transfer
Old   November 24, 2020, 15:08
Default Coupling Two Fluid Regions Differently to Solve Heat Transfer
Utkan Erdem
Utkan is on a distinguished road
Hello everyone,
I want to simulate the heat transfer between a car-radiator with an unmeshable geometry (I want to simulate the radiator as porous water) and two computer-cooling fans blowing air normal to the radiator plane. And afterwards, validate the simulation by comparing the outlet temperature of the water with varying air velocities, in a test rig.
Currently, I'm working with the heatExchanger case, under the chtMultiRegionFoam. However, in this case, water and air are coupled with "constantHeatTransfer" (uses a constant heat transfer coefficient and Area-over-Volume ratio of overlapping regions in calculating the transferred heat) and the simulation requires both inlet and outlet temperatures of each fluid specified. However, I want to be able to obtain an outlet temperature for porous water as an outcome of the simulation, I don't want to specify it beforehand.
I am definitely not a CFD expert but what I believe is that; I somehow need to couple the two-fluid regions by their velocity and pressure fields and have the case calculate the Navier-Stokes energy equation to give the outlet temperature.
Maybe also finding a way to use the thermal boundary condition of "compressible::turbulentTemperatureCoupledBaffleMi xed" in this case could also work. But I don't know if that can be done with porous regions.
I would be so happy if a senior member can show me a way with this. Thank you
Utkan is offline   Reply With Quote
heat exchanger two fluids, heat transfer modelling, porous coupling, porous flow
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 20:42
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
