November 24, 2020, 11:29 |
mergePatchPairs
Nikhil
Rep Power: 6 |
Hallo foamers,
I have 5 blocks, which have to be joined together and form 1 block. Only the faces exposed to the outside are supposed to be defined as patches. So, I want to merge faces that are in the middle of the domain. I tried to use mergePatchPairs for that, but unable to merge all patches. The following figures explain the problem more in detail. The yellow faces in the figure have to be merged (to internal faces) and blue faces have to defined as patches. blockMesh file is attached below. I used mergePatchPairs to merge faces, but it works for only any one of the blocks. for example, if I merge face from block 1 to face from block 2 then I cant merge the face from block 1 to face from block 3, don't know why it's not working. Is there any way to do this? Please someone shed some light on this. cheers, nick. Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( //block01 (-15 0.12 0.00)//0 ( 15 0.12 0.00)//1 ( 15 20.0 0.00) (-15 20.0 0.00) (-15 0.12 8.00)//4 ( 15 0.12 8.00)//5 ( 15 20.0 8.00) (-15 20.0 8.00) //block02 (-15 -0.40 0.00)//8 (-1 -0.40 0.00) (-1 0.12 0.00) (-15 0.12 0.00)//11 (-15 -0.40 8.00)//12 (-1 -0.40 8.00) (-1 0.12 8.00) (-15 0.12 8.00)//15 //block03 (-1 -0.40 0.00) (5.0 -0.40 0.00) (5.0 0.12 0.00) (-1 0.12 0.00) (-1 -0.40 8.00) (5.0 -0.40 8.00) (5.0 0.12 8.00) (-1 0.12 8.00) //block04 (5.0 -0.40 0.00) (15 -0.40 0.00)//25 (15 0.12 0.00)//26 (5.0 0.12 0.00) (5.0 -0.40 8.00) (15 -0.40 8.00)//29 (15 0.12 8.00)//30 (5.0 0.12 8.00) //block05 (-15 -20.0 0.00) ( 15 -20.0 0.00) ( 15 -0.40 0.00)//34 (-15 -0.40 0.00)//35 (-15 -20.0 8.00) ( 15 -20.0 8.00) ( 15 -0.40 8.00)//38 (-15 -0.40 8.00)//39 ); blocks //(0 1 3 2 4 5 7 6) ( hex (0 1 2 3 4 5 6 7) (60 60 20) simpleGrading (1 1 1) //block1 hex (08 09 10 00 12 13 14 04) (60 60 20) simpleGrading (1 1 1) //block2 hex (16 17 18 19 20 21 22 23) (60 60 20) simpleGrading (1 1 1) //block3 hex (24 25 01 27 28 29 05 31) (60 60 20) simpleGrading (1 1 1) //block4 hex (32 33 25 08 36 37 29 12) (60 60 20) simpleGrading (1 1 1) //block5 ); edges ( ); boundary ( bt01 { type empty; faces ( (0 1 5 4) ); } bt02 { type empty; faces ( (00 04 14 10) ); } bt03 { type empty; faces ( (19 23 22 18) ); } bt04 { type empty; faces ( (27 31 05 01) ); } up05 { type empty; faces ( (08 12 29 25) ); } up02 { type empty; faces ( (8 9 13 12) ); } up03 { type empty; faces ( (16 17 21 20) ); } up04 { type empty; faces ( (24 25 29 28) ); } rt02 { type empty; faces ( (9 10 14 13) ); } rt03 { type empty; faces ( (17 18 22 21) ); } lt03 { type empty; faces ( (16 20 23 19) ); } lt04 { type empty; faces ( (24 28 31 27) ); } ); mergePatchPairs ( (up05 up02) (up05 up03) (up05 up04) // (bt01 bt02) (bt01 bt03) (bt01 bt04) // //(rt02 lt03) //(rt03 lt04) // ); |
November 24, 2020, 22:37 |
Rep Power: 6 |
Hi Nick,
Can you please be more specific on this part? Do you get any error while running the application or it runs but does not create your desired result? If I am not mistaken, this bug report discusses a similar issue: https://bugs.openfoam.org/view.php?id=347 Cheers |
November 25, 2020, 16:14 |
Nikhil
Rep Power: 6 |
It's not running, getting an error same as in the issue: https://bugs.openfoam.org/view.php?id=347. I am facing a similiar issue,
Thanks for pointing to the link, now it's running without errors. But still confused about the difference between facematching, mergePatchPairs, and stichMesh features. When i used mergePatchPairs feature to merge 2 meshes, i got cell errors when using snappy, but with stichMesh it seems working. Dont know the reason :\ |
blockmesh, facematching, mergepatchpairs |
[blockMesh] mergePatchPairs master with few slaves | piprus | OpenFOAM Meshing & Mesh Conversion | 4 | May 24, 2024 14:24 |
[blockMesh] mergePatchPairs problem when migrating from OFext1.6 to OFext3.1 | ma-tri-x | OpenFOAM Meshing & Mesh Conversion | 2 | January 12, 2021 04:23 |
[mesh manipulation] mergePatchPairs after running blockMesh | ashishmagar600 | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2019 04:15 |
[blockMesh] mergePatchPairs reducing a face to less than 3 points | aow | OpenFOAM Meshing & Mesh Conversion | 2 | June 1, 2018 17:37 |
[mesh manipulation] mergePatchPairs with multiple areas | bjoern1 | OpenFOAM Meshing & Mesh Conversion | 1 | October 1, 2015 07:07 |
