November 4, 2020, 11:51 |
hollow volume in snappyhexmesh
Bineet Mehra
Rep Power: 13 |
I am trying to use snappyhexmesh to model a conjugate heat transfer problem. There are many solids to be cooled by a fluid. I am using .stl for different components to be meshed for a particular solid. However, not all of them are meshed properly. For example for a particular setting of blockMesh solid 1 is meshed while solid 2 is not meshed and its hollow (no volume mesh for solid 2 as seen in Paraview) and for other setting of blockMesh Solid 1 is not meshed ie hollow in paraview while solid 2 is meshed etc etc. Do you know why it is so and why the result depends so much on the background mesh given by blockMesh. Thanks in advance for help Last edited by bineet_aero; November 5, 2020 at 09:46. |
blockmesh, openfoam, snappyhexmesh |
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? | EternalSeekerX | SU2 | 3 | October 9, 2020 19:28 |
multiphaseEulerFoam high Courant number | Frenk_T | OpenFOAM | 5 | November 24, 2016 04:23 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
