OpenFoam Toposet
Old   November 3, 2020, 10:16
Default OpenFoam Toposet
Bineet Mehra
bineet_aero is on a distinguished road
I have a conjugate heat transfer problem, few electronic components being cooled directly by a fluid (immersion method of cooling) and i am using OpenFoam for this.
I am using toposet to identify different solid components inside the background mesh. Since some of the components are very thin (like a solder layer 0.1mm thick), i have to use a blockmesh with very high number of elements in each of the three axis. If the background mesh is not fine enough, toposet is unable to extract these thin solid components. I have to play with the backgroud blockmesh so as the toposet identifies all the solid cellZones successfully. Of course i can use snappy, but i do not think so i can get the same quality hexa mesh as given by blockMesh.
Any idea how to make sure that toposet identifies a particular cellZone successfully without using hit and trial with background blockMesh?
thanks
bineet_aero is offline   Reply With Quote
Old   November 7, 2020, 05:23
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
I am not sure I have understood correctly. Is your mesh from a blockMesh, or a different source? If it is a blockMesh, what happened to the cellZones from it?
olesen is offline   Reply With Quote
blockmesh, openfaom, toposet
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
OpenFOAM Foundation Releases OpenFOAM v2.3.0 opencfd OpenFOAM Announcements from OpenFOAM Foundation 3 December 23, 2014 04:43
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
