fluent3DMeshToFoam and mergeMeshes crash with large (around 170 mio cells) meshes
Old   November 3, 2020, 06:21
Default fluent3DMeshToFoam and mergeMeshes crash with large (around 170 mio cells) meshes
Max
maxdre91 is on a distinguished road
Dear all,
i am currently trying to convert ICEM generated large hexahedral meshes (170 mio cells; exported in ASCII) to openFOAM via fluent3DMeshToFoam on openFOAM v7. When i try so fluent3DMeshToFoam crashes at the save mesh step with the error message below.
As a workaround i tried to split my mesh into 3 smaller parts in order to merge them after the conversion with fluent3DMeshToFoam.
For all of these 3 parts of the mesh, the conversion via fluent3DMeshToFoam is successfull and checkMeshes also provides good results.
Now when i try to merge them in any possibility (1&2; 1&3; 2&3) mergeMesh crashes with the same error output as in the fluent3DMeshToFoam of the large mesh.
Below you can see an extract of the log-file from mergeMeshes.
Since this is a time sensitive matter for my work, Any help would be very appreciated, thanks!
log-file:
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigSegv::sigHandler(int) at ??:?
#2  ? in "/lib64/libc.so.6"
#3  Foam::polyTopoChange::makeCells(int, Foam::List<int>&, Foam::List<int>&) const at ??:?
#4  Foam::polyTopoChange::compact(bool, bool, int&, Foam::List<int>&, Foam::List<int>&) at ??:?
#5  Foam::polyTopoChange::compactAndReorder(Foam::polyMesh const&, bool, bool, bool, int&, Foam::Field<Foam::Vector<double> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::Map<int> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<Foam::Map<int> >&) at ??:?
#6  Foam::polyTopoChange::changeMesh(Foam::polyMesh&, bool, bool, bool, bool) at ??:?
#7  ? at ??:?
#8  __libc_start_main in "/lib64/libc.so.6"
#9  ? at ??:?
maxdre91 is offline   Reply With Quote
Old   December 11, 2020, 22:23
zhaobo
zhaobo is on a distinguished road
Dear Max:
Have you got any idea about it?I come up with nearly the same problem.
zhaobo is offline   Reply With Quote
Old   April 27, 2022, 09:44
Max
Yes, for me the solution was a new openfoam compilation with setting:
$WM_LABEL_SIZE in the /etc/bashrc file to be 64.
This way the large meshes could be handled.
