gmshToFoam unhandled element 1 at line... warning |
November 1, 2020, 12:54 |
Gerard Mayoral
Hello, i'm trying to import my .msh file into OpenFOAM with gmshToFoam command, but the "unhandled element 1 at line" warning appears. It is not a fatal error, but when i check the polyMesh folder, my physical surfaces are not readed at the boundary file.
Also when i run the checkMesh command, some errors appear. I write bellow the warnings that appear when i run the gmshToFoam command and the checkMesh command. Also i attached my .geo file. The file is a NACA4412 airfoil mesh. GMSHTOFOAM ERROR: ... Unhandled element 1 at line 70311 Unhandled element 1 at line 70312 Unhandled element 1 at line 70313 Unhandled element 1 at line 70314 Unhandled element 1 at line 70315 Unhandled element 1 at line 70316 Unhandled element 1 at line 70317 Unhandled element 1 at line 70318 Unhandled element 1 at line 70319 Unhandled element 1 at line 70320 Unhandled element 1 at line 70321 Unhandled element 1 at line 70322 Unhandled element 1 at line 70323 Unhandled element 1 at line 70324 Unhandled element 1 at line 70325 Unhandled element 1 at line 70326 Unhandled element 1 at line 70327 Unhandled element 1 at line 70328 Unhandled element 1 at line 70329 Mapping region 0 to Foam patch 0 Mapping region 0 to Foam cellZone 0 Cells: total:48978 hex :15805 prism:33173 pyr :0 tet :0 CellZones: Zone Size 0 48978 Skipping tag $Periodic at line 218849 Skipping tag at line 251695 Patch 0 gets name patch0 --> FOAM Warning : From function Foam:olyMesh:olyMesh(const Foam::IOobject&, const Foam::Xfer<Foam::Field<Foam::Vector<double> > >&, const cellShapeList&, const faceListList&, const wordList&, const wordList&, const Foam::word&, const Foam::word&, const wordList&, bool) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 595 Found 98659 undefined faces in mesh; adding to default patch. Finding faces of patch 0 FaceZones: Zone Size 0 881 Writing zone 0 to cellZone cellZone_0 and cellSet Writing zone 0 to faceZone faceZone_0 and faceSet End CHEKMESH ERROR: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 5.x-68e8507efb72 Exec : checkMesh Date : Nov 01 2020 Time : 18:47:01 Host : "eseiaat-linux" PID : 5181 I/O : uncollated Case : /home/sict/OpenFOAM/sict-5.0/run/TFG/Simulation nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 66286 internal points: 800 faces: 179677 internal faces: 81018 cells: 48978 faces per cell: 5.3227 boundary patches: 1 point zones: 0 face zones: 1 cell zones: 1 Overall number of cells of each type: hexahedra: 15805 prisms: 33173 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. ***Unused points found in the mesh, number unused by faces: 800 number unused by cells: 800 <<Writing 800 unused points to set unusedPoints Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology patch0 98659 65486 ok (closed singly connected) Checking geometry... Overall domain bounding box (-5 -3 0) (6 3 1) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-1.76157e-19 2.81852e-18 -1.10098e-20) OK. ***High aspect ratio cells found, Max aspect ratio: 17382.2, number of cells 12492 <<Writing 12492 cells with high aspect ratio to set highAspectRatioCells Minimum face area = 1.74493e-08. Maximum face area = 0.277055. Face area magnitudes OK. Min volume = 1.74493e-08. Max volume = 0.0253634. Total volume = 62.0451. Cell volumes OK. Mesh non-orthogonality Max: 33.1231 average: 8.56357 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.561509 OK. Coupled point location match (average 0) OK. Failed 2 mesh checks. End |
[Gmsh] gmshToFoam unhandled element | flowris | OpenFOAM Meshing & Mesh Conversion | 4 | February 20, 2023 17:50 |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 11:32 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
