Boundary conditions for a centrifugal pump inside a racecar in simpleFoam |
October 26, 2020, 02:27 |
Edoardo Gamba
Rep Power: 6 |
Hi everyone, I need to simulate the effects of a centrifugal fan which main task is to cool an electric motor, I want to use its outlet velocity to shape the flow in a manner that gives me more downforce.
The car is already solved in simpleFoam and I don't want to change that, I tought of adding a fixedJump in pressure to the inlet of the fan and adjusting the value until I got to the flowrate stated in the manufacturer specs. I'm sure there's a better way to do this but I don't have a lot of experience with fans in openFoam. The other BC I can think of is the fan but since the inlet and the outlet surfaces of the centrifugal fan are orthogonal i'm not sure if this will work well. Any help/hint/whatever is really appreciated (I never got a simulation with fans working so everything you can tell me is a big step forward for me) Thanks |
boundary condition, car aerodynamics, fan, fan as momentum source, simplefoam |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Fluent 15.0: Boundary Conditions for a Centrifugal Pump | _Arne_ | FLUENT | 2 | August 22, 2018 11:07 |
Wrong multiphase flow at rotating interface | Sanyo | CFX | 14 | February 7, 2017 17:19 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
