Directions exchange in number of cells input area
Old   October 23, 2020, 12:46
Default Directions exchange in number of cells input area
Chris Harding
HappyS5 is on a distinguished road
To me, this is odd and likely a bug.
I used pointField.H to build my full cylinder points. I got the following error:
'FOAM FATAL ERROR : Inconsistent number of faces between block pair 0 and 10'
Seemed my meshing wasn't matching up. With that said, I was confident I was correctly specifying the right number of cells for (x y z).
I found that the top half of my geometry hex blocks were normal:
hex (0 1 2 3 4 5 6 7) (x y z) simpleGrading (1 1 1).
I found that my bottom half of geometry was abnormal:
hex (0 1 2 3 4 5 6 7) (y x z) simpleGrading (1 1 1).
Notice, the number of cells exchanged.
Here is a video that walks through the error: https://youtu.be/bCU2XqcAmgs
To Reproduce:
Download case files and run:
>foamCleanTutorials
>foamCleanPolyMesh
>blockMesh
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices #codeStream
    codeInclude
        #include "pointField.H"
    code
        pointField points(19);
        points[0]  = point(-35, 0, 0);
        points[1]  = point(9, 0, 0);
        points[2]  = point(10, 0, 0);
        points[3]  = point(12, 0, 0);
        points[4]  = point(13, 0, 0);
        points[5]  = point(115, 0, 0);
        points[6]  = point(-35, 1.4142136, 0);
        points[7]  = point(9.5857864, 1.4142136, 0);
        points[8]  = point(11, 2, 0);
        points[9]  = point(12.4142136, 1.4142136, 0);
        points[10] = point(115, 1.4142136, 0);
        points[11] = point(-35, 50, 0);
        points[12] = point(9.5857864, 50, 0);
        points[13] = point(11, 50, 0);
        points[14] = point(12.4142136, 50, 0);
        points[15] = point(115, 50, 0);
        points[16] = point(10.292893, 0.707107, 0);
        points[17] = point(11, 1, 0);
        points[18] = point(11.707107, 0.707107, 0);
        // Duplicate z points
        label sz = points.size();
        points.setSize(2*sz);
        for (label i = 0; i < sz; i++)
            const point& pt = points[i];
            points[i+sz] = point(pt.x(), pt.y(), pt.z()+2);
        //Mirror above geometry in the -y direction
        label my = points.size();
        points.setSize(2*my);
        for (label i = 6; i < my; i++)
            if (i < 19)
                points[i+(my-6)] = point(pt.x(), -pt.y(), pt.z());
            if (i > 24 && i < 38)
                points[i+26] = point(pt.x(), -pt.y(), pt.z());
        //Print points
        for ( label k = 0; k < 2*my-12; k++)
            Info << "This is point:" << k << points[k] << endl;
        os  << points;
blocks
    //Normal cell numbering of (x y z):
    hex (0 1 7 6 19 20 26 25) (10 25 1) simpleGrading (1 1 1)//1
    hex (1 2 16 7 20 21 35 26) (10 25 1) simpleGrading (1 1 1)//2
    hex (7 16 17 8 26 35 36 27) (10 25 1) simpleGrading (1 1 1)//3
    hex (8 17 18 9 27 36 37 28) (10 25 1) simpleGrading (1 1 1)//4
    hex (3 4 9 18 22 23 28 37) (10 25 1) simpleGrading (1 1 1)//5
    hex (4 5 10 9 23 24 29 28) (10 25 1) simpleGrading (1 1 1)//6
    hex (6 7 12 11 25 26 31 30) (10 10 1) simpleGrading (1 1 1)//7
    hex (7 8 13 12 26 27 32 31) (25 10 1) simpleGrading (1 1 1)//8
    hex (8 9 14 13 27 28 33 32) (25 10 1) simpleGrading (1 1 1)//9
    hex (9 10 15 14 28 29 34 33) (10 10 1) simpleGrading (1 1 1)//10
    //Abnormal cell numbering of (y x z) :
    hex (0 38 39 1 19 51 52 20) (25 10 1) simpleGrading (1 1 1)//11
    hex (1 39 48 2 20 52 61 21) (25 10 1) simpleGrading (1 1 1)//12
    hex (39 40 49 48 52 53 62 61) (25 10 1) simpleGrading (1 1 1)//13
    hex (40 41 50 49 53 54 63 62) (25 10 1) simpleGrading (1 1 1)//14
    hex (3 50 41 4 22 63 54 23) (25 10 1) simpleGrading (1 1 1)//15
    hex (4 41 42 5 23 54 55 24) (25 10 1) simpleGrading (1 1 1)//16
    hex (38 43 44 39 51 56 57 52) (10 10 1) simpleGrading (1 1 1)//17
    hex (39 44 45 40 52 57 58 53) (10 25 1) simpleGrading (1 1 1)//18
    hex (40 45 46 41 53 58 59 54) (10 25 1) simpleGrading (1 1 1)//19
    hex (41 46 47 42 54 59 60 55) (10 10 1) simpleGrading (1 1 1)//20
edges
    arc 1 7 (9.1522409 0.76536686 0)//1
    arc 7 8 (10.234633 1.8477591 0)//2
    arc 8 9 (11.765367 1.8477591 0)//3
    arc 9 4 (12.847759 0.76536686 0)//4
    arc 2 16 (10.076120 0.38268343 0)//5
    arc 16 17 (10.617317 0.92387953 0)//6
    arc 17 18 (11.382683 0.92387953 0)//7
    arc 18 3 (11.923880 0.38268343 0)//8
    arc 20 26 (9.1522409 0.76536686 2)//9
    arc 26 27 (10.234633 1.8477591 2)//10
    arc 27 28 (11.765367 1.8477591 2)//11
    arc 28 23 (12.847759 0.76536686 2)//12
    arc 21 35 (10.076120 0.38268343 2)//13
    arc 35 36 (10.617317 0.92387953 2)//14
    arc 36 37 (11.382683 0.92387953 2)//15
    arc 37 22 (11.923880 0.38268343 2)//16
    //bottom geometry
    arc 1 39 (9.1522409 -0.76536686 0)//17
    arc 39 40 (10.234633 -1.8477591 0)//18
    arc 40 41 (11.765367 -1.8477591 0)//19
    arc 41 4 (12.847759 -0.76536686 0)//20
    arc 2 48 (10.076120 -0.38268343 0)//21
    arc 48 49 (10.617317 -0.92387953 0)//22
    arc 49 50 (11.382683 -0.92387953 0)//23
    arc 50 3 (11.923880 -0.38268343 0)//24
    arc 20 52 (9.1522409 -0.76536686 2)//25
    arc 52 53 (10.234633 -1.8477591 2)//26
    arc 53 54 (11.765367 -1.8477591 2)//27
    arc 54 23 (12.847759 -0.76536686 2)//28
    arc 21 61 (10.076120 -0.38268343 2)//29
    arc 61 62 (10.617317 -0.92387953 2)//30
    arc 62 63 (11.382683 -0.92387953 2)//31
    arc 63 22 (11.923880 -0.38268343 2)//32
boundary
    bottomWall
        type symmetry;
        faces
           (43 44 57 56)
           (44 45 58 57)
           (45 46 59 58)
           (46 47 60 59)
    outlet
        type patch;
        faces
            (10 15 34 29)
            (5 10 29 24)
            (5 24 55 42)
            (42 55 60 47)
    topWall
        type symmetry;
        faces
            (11 30 31 12)
            (12 31 32 13)
            (13 32 33 14)
            (14 33 34 15)
    inlet
        type patch;
        faces
            (6 25 30 11)
            (0 19 25 6)
            (0 38 51 19)
            (38 43 56 51)
    cylinder
        type wall;
        faces
            (2 16 35 21)
            (16 17 36 35)
            (17 18 37 36)
            (3 22 37 18)
            (2 21 61 48)
            (48 61 62 49)
            (49 62 63 50)
            (3 50 63 22)
    frontandBack
        type empty;
        faces
            //back
            (0 6 7 1)
            (1 7 16 2)
            (7 8 17 16)
            (8 9 18 17)
            (3 18 9 4)
            (4 9 10 5)
            (6 11 12 7)
            (7 12 13 8)
            (8 13 14 9)
            (9 14 15 10)
            //(1 2 48 39)
            //front
            (19 20 26 25)
            (20 21 35 26)
            (26 35 36 27)
            (27 36 37 28)
            (22 23 28 37)
            (23 24 29 28)
            (25 26 31 30)
            (26 27 32 31)
            (27 28 33 32)
            (28 29 34 33)
mergePatchPairs
HappyS5 is offline   Reply With Quote
Old   October 24, 2020, 16:15
Default Hrvoje Jasak Answer
Chris Harding
"Not a bug. Definition of a block defines its internal coordinate system. You ordered the block the wrong way round. I know: I personally wrote this code in 1994 and use it regularly."- https://www.linkedin.com/feed/update...02959824898%29
Basically, I have sloppy code. I will work on that. If I figure out where I got confused, I will return and explain what I did to resolve the issue.
Old   October 26, 2020, 15:35
Default Appropriately ordered blocks
Chris Harding
In truth, I missed the "local coordinate" information when I read: https://cfd.direct/openfoam/user-guide/v8-blockMesh/
I had numbered the hex block wrong. Vertex 0 --> vertex 1 specifies x1.
Here is the new blockMeshDict:
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
convertToMeters 0.01;
    codeInclude
    code
            if (i < 19)
        //Print points
        os  << points;
blocks
    //Normal cell numbering of (x1 x2 x3):
    //Fixed and matching cell numbering of (x1 x2 x3) :
    hex (38 39 1 0 51 52 20 19) (10 25 1) simpleGrading (1 1 1)//11
    hex (39 48 2 1 52 61 21 20) (10 25 1) simpleGrading (1 1 1)//12
    hex (40 49 48 39 53 62 61 52) (10 25 1) simpleGrading (1 1 1)//13
    hex (41 50 49 40  54 63 62 53) (10 25 1) simpleGrading (1 1 1)//14
    hex (50 41 4 3 63 54 23 22) (10 25 1) simpleGrading (1 1 1)//15
    hex (41 42 5 4 54 55 24 23) (10 25 1) simpleGrading (1 1 1)//16
    hex (43 44 39 38 56 57 52 51) (10 10 1) simpleGrading (1 1 1)//17
    hex (44 45 40 39 57 58 53 52) (25 10 1) simpleGrading (1 1 1)//18
    hex (45 46 41 40 58 59 54 53) (25 10 1) simpleGrading (1 1 1)//19
    hex (46 47 42 41 59 60 55 54) (10 10 1) simpleGrading (1 1 1)//20
edges
    //bottom geometry
boundary
    bottomWall
        type symmetry;
        faces
           (43 44 57 56)
           (44 45 58 57)
           (45 46 59 58)
           (46 47 60 59)
    outlet
        type patch;
        faces
            (10 15 34 29)
            (5 10 29 24)
            (5 24 55 42)
            (42 55 60 47)
    topWall
        type symmetry;
        faces
            (11 30 31 12)
            (12 31 32 13)
            (13 32 33 14)
            (14 33 34 15)
    inlet
        type patch;
        faces
            (6 25 30 11)
            (0 19 25 6)
            (0 38 51 19)
            (38 43 56 51)
    cylinder
        type wall;
        faces
            (2 16 35 21)
            (16 17 36 35)
            (17 18 37 36)
            (3 22 37 18)
            (2 21 61 48)
            (48 61 62 49)
            (49 62 63 50)
            (3 50 63 22)
    frontandBack
        type empty;
        faces
            //back
            (0 6 7 1)
            (1 7 16 2)
            (7 8 17 16)
            (8 9 18 17)
            (3 18 9 4)
            (4 9 10 5)
            (6 11 12 7)
            (7 12 13 8)
            (8 13 14 9)
            (9 14 15 10)
            //(1 2 48 39)
            //front
            (19 20 26 25)
            (20 21 35 26)
            (26 35 36 27)
            (27 36 37 28)
            (22 23 28 37)
            (23 24 29 28)
            (25 26 31 30)
            (26 27 32 31)
            (27 28 33 32)
            (28 29 34 33)
mergePatchPairs
blockmeshdict block mesh
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) AndreP STAR-CCM+ 10 August 2, 2018 08:48
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
CFX Solver Memory Error mike CFX 1 March 19, 2008 08:22
