Periodic boundary condition for two phase flow in OpenFoam?
Old   October 19, 2020, 06:41
Default Periodic boundary condition for two phase flow in OpenFoam?
ESI
ht2017 is on a distinguished road
Does OpenFoam allow us to apply periodic boundary conditions (PBC) for two-phase flow?
I have a case run for a 3D channel with the water and air. The water moving above the air and the water have velocity for an inlet. The air doesn't move.
Can we apply PBC at inlet and outlet to obtain the fully developed velocity profile?
I have used a cyclic boundary condition for the inlet and outlet but I don't know how to set up the velocity for the water. I referred the tutorial
HTML Code:
$FOAM_TUTORIALS/incompressible/pimpleFoam/LES/channel395
but it is using for single flow.
ht2017 is offline   Reply With Quote
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
CFX, multiphase flow, boundary condition is only valid for a phase hellowqy CFX 0 October 12, 2016 07:20
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
