ChemkinToFoam Converter can't able to convert GRI mech30 files to foam type.
Old   October 17, 2020, 04:30
Default ChemkinToFoam Converter can't able to convert GRI mech30 files to foam type.
Janeshwar Sharma
Janeshwar is on a distinguished road
i am doing combustion modeling in a rectangular domain with fuel inlet at center.(Fuel is methanol) so i am using GRI mech30 reaction with 30 species, I cant able to convert GRI30 reaction files to foam format using Chemkin Foam.
The error produced is-
--> FOAM FATAL IO ERROR:
"ill defined primitiveEntry starting at keyword 'AR' on line 1 and ending at line 112"
file: transport.dat at line 112.
From the function void Foam:rimitiveEntry::readEntry(const Foam::dictionary&, Foam::Istream&)
in file db/dictionary/primitiveEntry/primitiveEntryIO.C at line 185.
On the internet I don't get the solution anywhere.
Janeshwar is offline   Reply With Quote
Old   November 9, 2020, 17:34
det
Daniel Thomas
det is on a distinguished road
You've probably figured it out by now, but you should check your thermo file format. With OpenFOAM 8, the thermo file should begin with something like:
species    36 (AR He <Symbols of remaining 34 species> );
det is offline   Reply With Quote
combustion, openfoam, reactingfoam
natural convection in square cavity having inlet and outlet sujeet OpenFOAM Running, Solving & CFD 1 November 2, 2019 03:17
Foam::error::printStack(Foam::Ostream&) at ??:? mdhfiz OpenFOAM Running, Solving & CFD 1 September 19, 2019 10:46
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 18:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
