Outlet behaves like solid wall
Old   September 14, 2020, 12:20
Default Outlet behaves like solid wall
Harald Radlwimmer
Harald is on a distinguished road
earlier this year, I started using OpenFOAM at work. Now, I reached the point, where I need assistance.
Currently, I got stuck with the correct definition of my problem's outlet boundary conditions.
My test case has the following setup:
  • axis-symmetric case (see 1-geom.png):
    • chamber (D = 25 mm) with small high-pressure/temperature region,
    • filter,
    • surrounding area
  • initial conditions (see 2-initial-p.png and 2-initial-T.png):
    • air
    • p0 = 1e+05 Pa
    • T0 = 300 K
    • chamber (high temperature/pressure region)
      • air
      • p_region = 20e+05 Pa
      • T_region = 1600 K
    • filter (Darcy-Forchheimer)
  • outlet patches
    • front,
    • right
  • solver
    • rhoPimpleFoam
Currently, my outlet patches seem to behave like solid walls. This understanding comes from the observation of a reflection from the front-patch (see 3-U.png and 4-U.png). However, that is not what I want. Actually, the outlet patch should be perfectly permeable and, therefore, only cut away everything from the environment, which I do not want to simulate.
Unfortunately, I could not find the solution myself (RAS-tutorials, foamInfo, etc.). Please, take a look at my outlet boundary conditions; can you find an obvious failure?
alphat:
"(front|right)"// outlet
type calculated; value uniform 0;
 k:
type inletOutlet; inletValue uniform 1e-5; value uniform 1e-5;
 nut:
omega:
type inletOutlet; value uniform 1; inletValue uniform 1;
p:
type fixedValue; value uniform 1e+5;
T:
type inletOutlet; value uniform 300; inletValue uniform 300;
 U:
type pressureInletOutletVelocity; value uniform (0 0 0); inletValue uniform (0 0 0);
Let me know if I need to provide some additional information.
Harald
Harald is offline   Reply With Quote
Old   September 16, 2020, 06:46
Default Setting pressure outlet BC to waveTransmissive helped
Harald Radlwimmer
Today, I found a solution for my problem with help of foamInfo. It seems that changing the outlet boundary condition of the pressure from fixedValue to waveTransmissive does the job (see 5-U.png,6-U.png).
The new outlet BC reads:
p:
"(right|front)"// outlet
type waveTransmissive; gamma 1.4;
boundary condition, outlet, wall
temperature correction limited- Star ccm+ LpSingh STAR-CCM+ 15 September 29, 2020 12:06
Wall shear stress for solid phase? qi.yang@polimi.it OpenFOAM Programming & Development 0 February 24, 2020 07:26
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 06:43
Problem Interface Solid Fluid with wall velocity Solver v12 hills1 CFX 2 October 12, 2009 06:36
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
