Setting a OpenFoam turbulence case without wall functions
Old   September 9, 2020, 10:36
Exclamation Setting a OpenFoam turbulence case without wall functions
Lucie Recurt
lucie.recurt is on a distinguished road
Hello everyone!
I have, for my internship, simulate a turbulent flow in a pipe with a part that make the flow rotating. And I have to test different turbulence models to know which one is the closer to experimental results.
I have read on Internet and thesis that wall functions are not really appropriate for rotating flows that why I don't want to use wall functions.
But I don't understand what to put as boundary condition for the turbulence fields...
Does someone have some clues on how to do that?
Thank you in advance
lucie.recurt is offline   Reply With Quote
Old   September 9, 2020, 23:07
Ardalan
Ardali is on a distinguished road
Your question is too wide.
Which turbulence model do you want to conduct?
Generally omega, k, epsilon ~ zero, but not zero. LaunderSharma and other low Re models are fine with this setup.
LRR and SSG need another setup.
Ardali is offline   Reply With Quote
Old   September 10, 2020, 04:49
Lucie Recurt
Thank you for your answer.
First I tried with LienCubicKE and the solver simpleFoam. My case is running but the residuals still very high (> 1e-3).Here are my epsilon, k and nut file.
epsilon:
| \\ / O peration | Version: v2006 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object epsilon;
dimensions [0 2 -3 0 0 0 0];
internalField uniform 0.0000037595646871170543;
boundaryField
inlet
type turbulentMixingLengthDissipationRateInlet;
mixingLength 1;
value uniform 0.7815948027769771;
outlet
type inletOutlet;
inletValue uniform 0.7815948027769771;
"q_wall|cone_wall|e_wall|r_wall|t_wall"
type fixedValue;
value uniform 1e-12;
k:
FoamFile
version 2.0;
format ascii;
location "0";
object k;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0.000015915700576801106;
boundaryField
inlet
type turbulentIntensityKineticEnergyInlet;
intensity 0.016271391811637923;
value uniform 0.016271391811637923;
outlet
type inletOutlet;
inletValue uniform 0.016271391811637923;
type fixedValue;
nut:
FoamFile
version 2.0;
format ascii;
location "0";
object nut;
dimensions [0 2 -1 0 0 0 0];
internalField uniform 6.063961956727736;
boundaryField
inlet
type calculated;
value uniform 6.063961956727736;
outlet
type calculated;
"q_wall|cone_wall"
type calculated;
Ks uniform 1.96E-08;
Cs uniform 0.5;
r_wall
type calculated;
value uniform 26.856840909480123;
Ks uniform 3.13E-06;
Cs uniform 0.5;
t_wall
type calculated;
value uniform 30.4866884340128;
Ks uniform 1.47E-06;
Cs uniform 0.5;
e_wall
type calculated;
value uniform 18.782659668926282;
Cs uniform 0.5;
Old   September 10, 2020, 09:21
Ardalan
If that is running with the model that you mentioned, cheers.
The BCs are practically correct.
You should keep your yPlus below zero in all time and space.
Old   December 30, 2020, 16:21
Josef Dobeš
Iose is on a distinguished road
Hi lucie.recurt,
can I have question regarding your values for k, epsilon and nut - how did you calculate them? Especially you have different values for internalField and for boundaries.
Thanks
Iose is offline   Reply With Quote
boundary, field, openfoam, turbulence, wall functions
CHT turbulence model wall functions julieng OpenFOAM Running, Solving & CFD 5 January 31, 2023 18:37
Wall Functions & Turbulence Models Query [y plus ranges] TheMightySpartan FLUENT 4 August 18, 2018 03:48
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 06:40
abt near wall turbulence wall functions amv Main CFD Forum 0 May 12, 2003 04:38
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
