Problems converting from OP7 to OP8 in multiphaseEulerFoam |
September 3, 2020, 16:47 |
Santa Catarina
Rep Power: 8 |
Dear all, let's see if someone can help me.
Me and my students are simulating air-water flow inside a vertical pipe using multiphaseEulerFoam and our cases worked well in version 7. Once we try to convert version 8 all hell breacks lose and we can't solve the problem. It wont go past the first time step. Have any of you ported the files from one to the other? Thanks. |
September 3, 2020, 18:05 |
Herpes Free Engineer
Rep Power: 13 |
OF went through a considerable restructruring from v7 to v8, possibly one of the largest since the outset of the software.
Therefore, I kindly suggest you to first understanding the new code suite, and rewrite whatever you have in v7 into v8.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
September 7, 2020, 13:23 |
Mark Olesen
Rep Power: 40 |
Might be useful to try with OpenFOAM-v2006 to see if it works there.
If you have redhat/centos/fedora/opensuse/ubuntu, a precompiled binary package would be a quick way to test. |
multiphaseeulerfoam |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 12:12 |
[Commercial meshers] Problems converting a Fluent case file | McFly | OpenFOAM Meshing & Mesh Conversion | 12 | July 21, 2019 22:02 |
Problems converting simpleFoam/motorBike to kOmegaSSTDES | perjorgen | OpenFOAM Running, Solving & CFD | 1 | October 28, 2016 08:11 |
[Commercial meshers] Problems after converting a CCM Model | sErik | OpenFOAM Meshing & Mesh Conversion | 10 | November 24, 2009 04:37 |
[Commercial meshers] Several problems with the mesh conversion utility when converting the meshes from Gridgen | su_junwei | OpenFOAM Meshing & Mesh Conversion | 2 | July 27, 2008 00:58 |
