How to select physical volume in Gmsh
Old   July 28, 2020, 02:41
Default How to select physical volume in Gmsh
Ariful Islam Pranto
Pranto is on a distinguished road
In my geometry, I have two cylinder which is indicated by 'volume-1' and 'volume-2'. But I can't add physical volume for these two cylinder separately.
Why is that and What is the solution?
In chtMultiregion case problem, I have to split mesh region, If I can't add physical volume
Does splitMeshRegion split mesh into multiple region?
This time I have tried with a single cylinder but gmshToFoam gives the following error
Starting to read mesh format at line 2
Read format version 4.1 ascii 0
Starting to read physical names at line 5
Physical names:3
Skipping tag $Entities at line 11
Starting to read points at line 23
Vertices to be read:9
--> FOAM FATAL IO ERROR:
Attempt to get back from bad stream
file: IStringStream.sourceFile at line 0.
From function bool Foam::Istream::getBack(Foam::token&)
in file db/IOstreams/IOstreams/Istream.C at line 56.
FOAM exiting
I am using Gmsh 4.6.0.
Pranto is offline   Reply With Quote
Old   August 12, 2023, 18:12
BISSAI NKAA
sante_junior is on a distinguished road
Physical names:3
FOAM exiting
Hi
First solve your problem with gmsh, then I'll be able to help you.
sante_junior is offline   Reply With Quote
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
How to use "translation" in solidBodyMotionFunction in OpenFOAM rupesh_w OpenFOAM Running, Solving & CFD 5 August 16, 2016 05:27
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 17:12
