Trouble to see the results of SetFields
Old   June 14, 2020, 22:31
Default Trouble to see the results of SetFields
Cristian David Vargas
CDVS is on a distinguished road
Hi. I recently installed to my laptop Ubunto 20 and after I run setFields, it run, but I tried to see the alpha.water from nano, to see the change, but it didn't response so I couldn't see the list of numbers, it's not possible to see the list, the weird is that I executed the solver and it run ok but I couldn't see this file, and I tried to read the file on windows and this can be open but in the list appear null value. It never happened to me on windows, can someone tell me why? by the way I'm using OpenFoam foundation 7.
CDVS is offline   Reply With Quote
Old   March 3, 2021, 06:50
Default Same problem
Maxime
dundu is on a distinguished road
Same problem, this is how it appears in my alpha.liquid once I have run setFields:
FoamFile:
version 2.0;
format binary;
class volScalarField;
arch "LSB;label=32;scalar=64";
location "0";
object alpha.liquid;
dimensions [0 0 0 0 0 0 0];
internalField nonuniform List<scalar>
6500
(^@^@^@^@^@^@�?^@^@^@^@^@^@�?^@^@^@^@^@^@�?^@^@^@^ @^@^@�?^@^@^............ etc....
boundaryField
leftWall
type zeroGradient;
My setFieldsDict:
defaultFieldValues
volScalarFieldValue alpha.liquid 0
volScalarFieldValue T 300
regions
boxToCell
box (0 0 -1) (0.01 0.01 1);
fieldValues
volScalarFieldValue alpha.liquid 1
volScalarFieldValue T 970
Did you solve your problem in between?
Thank you in advance,
Max
dundu is offline   Reply With Quote
Old   March 10, 2021, 09:25
Default Solved
Maxime
In conrolDict, make sure the writeFormat is ascii and not binary. It solved the problem.
Old   April 10, 2021, 19:21
Claudio Boezio
Ship Designer is on a distinguished road
The alpha field can also be visualized for inspection with ParaView. I prefer ascii format with compression over binary format for two reasons:
  1. Ascii with compression takes up less disk space than binary files.
  2. If needed, the file can be decompressed and its content is still human-readable.
Some utilities will crash though because they can't read compressed files. The stitchMesh utility in Foundation OpenFOAM for example cannot read compressed meshPhi files.
Ship Designer is offline   Reply With Quote
setfields, text editor, view
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 10 May 13, 2018 19:28
lid driven cavity varying results yasmil OpenFOAM Running, Solving & CFD 2 October 6, 2016 22:42
Oscillating Airfoil Poor Results at High k (reduced frequency) dancfd OpenFOAM Running, Solving & CFD 3 November 4, 2013 09:32
CFD results not close to experimental results cider STAR-CCM+ 0 July 8, 2013 08:53
Creating a tool to interpolate results Luis Batista OpenFOAM Running, Solving & CFD 2 April 11, 2013 09:15
