SRFSimpleFoam inlet pressure
Old   June 3, 2020, 11:17
Default SRFSimpleFoam inlet pressure
Maciej
Gorloj is on a distinguished road
Hey, I'm having trouble setting the turbulence flow pressure through the centrifugal pump impeller. I need to consaider some flow cases. When trying to use totalPressure in 0/p file, after 75 iterations the solver stopped working/ Maybe someone have some ideas how to set inlet pressure? Fluid is water.
internalField uniform 0;
boundaryField
inlet
type totalPressure;
rho none;
p0 uniform 0;
value uniform 0;
outlet
type zeroGradient;
walls1
type zeroGradient;
walls
type zeroGradient;
canals
type zeroGradient;
Gorloj is offline   Reply With Quote
boundary condition p, pressure, turbulence
Adjuting oulet pressure till inlet pressure reaches a certain value in timestep pvpnrao OpenFOAM Running, Solving & CFD 2 September 11, 2018 11:14
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 11:08
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 18:16
Assign static pressure at inlet Tanjina FLUENT 0 November 3, 2013 12:34
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
