Unable to generate OBJ file for OpenFOAM
Old   May 22, 2020, 20:46
Default Unable to generate OBJ file for OpenFOAM
anonymous
felik9 is on a distinguished road
I am trying to generate an obj file from a 3D model that I created in Inventor 2016. However, the OBJ file format is not available in this program when I tried to export my model. Does OpenFOAM support another type of CAD forrmat that I could use, like STEP or JT file format?
felik9 is offline   Reply With Quote
Old   May 29, 2020, 04:38
geth03 is on a distinguished road
OpenFOAM supports following file formats:
File extension Format description
.ftr OpenFOAM triangulated format
.stl Stereolithography (STL), ASCII
.stlb Stereolithography (STL), binary
.obj Wavefront object (OBJ)
.off 3D Object File Format (OFF)
.vtk Visualisation Toolkit (VTK)
.tri Triangle format
.ac Inivis AC3D
.smesh TenGen surface mesh format
.gts Midas Geotechnical & Tunnel analysis System (GTS)
.dx OpenDX format
geth03 is offline   Reply With Quote
cad format
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 22:03
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
