What is the reason not allowing to continue the simulation
Old   May 20, 2020, 17:32
Question What is the reason not allowing to continue the simulation
Davyd is on a distinguished road
Please could someone explain me the reason why the simulation is not running?
I am working with OpenFOAM-v1912 and using reactingTwoPhaseEulerFoam solver. I am applying reactingTwoPhaseEulerFoam tutorial (laminar fluidised bed) modified using chemistry from other reactingTwoPhaseEulerFoam tutorial - bubbleColumnEvaporatingReacting.
Here is the result I got:
| \\ / O peration | Version: v1912 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
Build : _f3950763fe-20191219 OPENFOAM=1912
Arch : "LSB;label=32;scalar=64"
Exec : reactingTwoPhaseEulerFoam
Date : May 20 2020
Time : 19:52:24
Host : LAPTOP-LTH2ON9V
PID : 2578
I/O : uncollated
Case : /mnt/c/Users/David/Downloads/OpenFOAM/OpenFOAM-v1912/RUN/fluidisedBed_REACTING_bcolumn
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: no residual control data found. Calculations will employ 3 corrector loops
Reading g
Reading hRef
Creating phaseSystem
Selecting twoPhaseSystem interfaceCompositionPhaseChangeTwoPhaseSystem
Selecting phaseModel for air: reactingPhaseModel
Selecting diameterModel for phase air: isothermal
Selecting thermodynamics package
type heRhoThermo;
mixture reactingMixture;
transport sutherland;
thermo janaf;
equationOfState perfectGas;
specie specie;
energy sensibleInternalEnergy;
Selecting chemistryReader foamChemistryReader
elements not defined in "/mnt/c/Users/David/Downloads/OpenFOAM/OpenFOAM-v1912/RUN/fluidisedBed_REACTING_bcolumn/constant/reactions.air"
Calculating face flux field phi.air
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
Selecting combustion model PaSR
Selecting chemistry solver
solver EulerImplicit;
method standard;
StandardChemistryModel: Number of species = 7 and reactions = 1
using integrated reaction rate
Selecting phaseModel for particles: purePhaseModel
Selecting diameterModel for phase particles: constant
type heRhoThermo;
mixture pureMixture;
transport const;
thermo eConst;
equationOfState perfectFluid;
specie specie;
Calculating face flux field phi.particles
Selecting turbulence model type RAS
Selecting RAS turbulence model phasePressure
phasePressureCoeffs
preAlphaExp 500;
expMax 1000;
alphaMax 0.62;
g0 1000;
No MRF models present
Selecting default blending method: linear
Selecting heatTransfer blending method: linear
Selecting massTransfer blending method: linear
Selecting surfaceTensionModel for (air and particles): constant
Selecting aspectRatioModel for (particles in air): constant
Selecting dragModel for (particles in air): GidaspowErgunWenYu
Selecting swarmCorrection for (particles in air): none
Selecting virtualMassModel for (particles in air): constantCoefficient
Selecting virtualMassModel for (air in particles): constantCoefficient
Selecting heatTransferModel for (particles in air): RanzMarshall
Selecting heatTransferModel for (air in particles): spherical
Selecting heatTransferModel for (particles in air): spherical
Selecting heatTransferModel for (air in particles): RanzMarshall
LAPTOP-LTH2ON9V:OpenFOAM/OpenFOAM-v1912/RUN/fluidisedBed_REACTING_bcolumn$
After that the simulation is stopped.
Who knows the reason or at least possible reason your suggestions are highly appreciated.
Davyd is offline   Reply With Quote
Old   May 29, 2020, 04:40
geth03 is on a distinguished road
can you share your phaseProperties-file input?
geth03 is offline   Reply With Quote
Old   May 29, 2020, 15:50
Sure I can:
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object phaseProperties;
type interfaceCompositionPhaseChangeTwoPhaseSystem;
phases (air particles);
air
type reactingPhaseModel;
diameterModel isothermal;
isothermalCoeffs
d0 1e-4;
p0 1e5;
Sct 1.4;
residualAlpha 0;
particles
type purePhaseModel;
diameterModel constant;
constantCoeffs
d 1e-4;
alphaMax 0.62;
residualAlpha 1e-6;
blending
default
type linear;
minFullyContinuousAlpha.air 0.4;
minPartlyContinuousAlpha.air 0;
minFullyContinuousAlpha.particles 0.4;
minPartlyContinuousAlpha.particles 0;
heatTransfer
type linear;
massTransfer
type linear;
surfaceTension
(air and particles)
type constant;
sigma 0;
aspectRatio
(particles in air)
type constant;
E0 1.0;
drag
(air in particles)
type GidaspowErgunWenYu;
residualRe 1e-3;
swarmCorrection
type none;
(particles in air)
residualRe 1e-3;
swarmCorrection
type none;
virtualMass
(air in particles)
type constantCoefficient;
Cvm 0.5;
(particles in air)
Cvm 0.5;
(particles in air)
type saturated;
species ( NH3 );
Le 1.79;
saturationPressure
type ArdenBuck;
heatTransfer.air
(air in particles)
type spherical;
residualAlpha 1e-3;
(particles in air)
type RanzMarshall;
residualAlpha 1e-3;
heatTransfer.particles
(air in particles)
type RanzMarshall;
residualAlpha 1e-3;
(particles in air)
type spherical;
residualAlpha 1e-3;
massTransfer.air
(air in particles)
type spherical;
Le 1.79;
(particles in air)
type Frossling;
Le 1.79;
massTransfer.particles
(air in particles)
type Frossling;
Le 1.79;
(particles in air)
type spherical;
Le 1.79;
phaseTransfer
lift
wallLubrication
turbulentDispersion
// Minimum allowable pressure
pMin 10000;
Old   June 2, 2020, 05:23
well, from your first post, i can see that the solver stops when the phaseproperties dict is been read.
i can't judge if you incorporated everything correctly though.
the simulation doesn't even start, so i won't think that its something related to BC's or IC's.
if something you entered is not in the options list, then openfoam should normally tell, which options are possible.
those crashes without any error output are hard to find the origin of the failure.
i suggest that you start with the example tutorial and then change the settings step by step.at every new step run the solver just to see if it stops working or if its continues. it will be easier to find the cause.
Old   June 6, 2020, 06:20
Ok, thanks for your suggestion.
Control simulation to apply different fields with chtMultiRegionFoam jmdf OpenFOAM Running, Solving & CFD 0 February 29, 2016 08:05
restarting paused transient simulation using reactingFoam JMDag2004 OpenFOAM Running, Solving & CFD 1 August 10, 2015 11:15
Use homogeneous results as the initial guess for an inhomogeneous simulation JuPa CFX 5 December 26, 2014 14:44
Discrete event simulation vs. fixed time (discrete time simulation) jenjon FLUENT 0 March 10, 2013 07:58
Simulation and Optimisation of centrifugal fan 3D to 2D eRzBeNgEl STAR-CCM+ 0 January 31, 2013 14:21
