reactingTwoPhaseEulerFoam fluidized bed
Old   May 12, 2020, 06:46
Question reactingTwoPhaseEulerFoam fluidized bed
Davyd is on a distinguished road
Please, could someone tell me how to add chemistry to the existing tutorial reactingTwoPhaseEulerFoam--->laminar--->fluidisedBed, since although it names "reacting" there are no files responsible for reactions inside, the content is absolutely the same as just TwoPhaseEulerFoam--->laminar--->fluidisedBed.
I have to simulate a catalytic reaction in a gas-solid fluidised bed catalytic reactor.
Thank you in advance for your help.
Davyd is offline   Reply With Quote
Old   May 27, 2020, 06:50
李玉玺
YX.L is on a distinguished road
Hi,I am using reactingTwoPhaseEulerFoam to simulate the combustion reaction of gas-solid fludised bed.
1 I am a new fomer,in my opinion ,the solver is suitable for gas-gas reaction,so we need add the gas-solid reacting in the solver . --->we can get the reaction rate of gas-solid reaction.
2 we need change the goverming equation (use the gas-solid rate)
3 I imitate the case RAS->bubbleColumnEvaporatingReacting->constant->reaction.gas
YX.L is offline   Reply With Quote
Old   May 29, 2020, 16:09
Thank you for the reply.
Is your simulation successful? I am trying to use files responsible for reactions from bubbleColumnEvaporatingReacting (actually I have copied them to the tutorial of a fluidised bed of a reactingTwoPhaseEulerFoam and modified them according to my case), however all time I get different errors and can not start simulation. Your field of simulation is similar to mine, therefore if everything is ok with your case maybe you will be able to help me
Old   December 20, 2020, 10:19
Hello, do you have the success in your simulation?
Old   December 20, 2020, 20:19
Haynes
h_kuriakose is on a distinguished road
i used this document to do the bubbleColumnEvaporatingReacting Tutorial,incase you haven't already found it.
http://www.tfd.chalmers.se/~hani/kur...eEulerFoam.pdf
http://www.tfd.chalmers.se/~hani/kur...n_CAPPELLI.pdf
h_kuriakose is offline   Reply With Quote
Old   December 21, 2020, 15:38
Actually, I want to simulate the fluidized bed catalytic reactor. However, since there is no chemistry in the "fluidisedBed" folder of the reactingTwoPhaseEulerFoam tutorial, I am trying to use the bubbleColumnEvaporatingReacting to add chemistry to the fluidisedBed case. Now I think maybe it is possible just to change the bubbleColumnEvaporatingReacting accordingly to make it suitable for use as a fluidized bed.
Old   December 21, 2020, 18:10
MetEng is on a distinguished road
I am not sure if you solved your problem. I am not familiar with the bubbleColumnEvaporatingReacting solver but i looked at the configuration and from what i can tell it is setup to model evaporation of a liquid species coupled with gas-gas phase reactions of the evaporated species.
If you are trying to do some sort of gas-solid or gas-liquid surface based reaction at a particulate or droplet interface in your fluidized bed you may have an easier time using the coalChemistryFoam solver and building a custom surface reaction model to capture the adsorption, reaction, and desorption behavior at the catalyst surface.
Note: you will also need to update the thermophysicalProperties library to include the solids your bed is made of for an accurate particulate model.
MetEng is offline   Reply With Quote
Old   December 22, 2020, 09:53
Thanks for you advice. Yes, I have to simulate the gas-solid fluidized bed catalytic reactor. So, I will try to use coalChemistryFoam as you proposed, have you made the similar in the past?
Old   March 17, 2021, 05:05
Maharashtra
B00BY is on a distinguished road
Did you get any success in your simulaion?
B00BY is offline   Reply With Quote
Old   March 17, 2021, 07:13
No, I switched to the comsol multiphysics.
fluidisedbed, reactingtwophaseeulerfoam
Solid particle in bubbling fluidized bed eman Fluent Multiphase 1 December 15, 2018 08:07
CFD-DEM simulation of fluidized bed nkidol08 Fluent Multiphase 0 February 23, 2017 08:47
Gas-solid modeling (Fluidized Bed) nezam.aziz@gmail.com Fluent Multiphase 0 August 29, 2013 07:40
Fluidized bed modeling Kartus CFX 9 June 30, 2011 05:41
Fluidized bed simulation VS particle tracking windhair CFX 2 June 28, 2011 22:10
