May 5, 2020, 09:31 |
error when using mapfields utility
mostafa kamal
Rep Power: 7 |
hello everyone
i want some help as i want to map results from mesh to another mesh in openfoam but with different geometry and boundary conditions,so i found the utility mapfields so i run mapfields with the mapfieldsdict in the system folder and the result was interpolated well to the other mesh. but when i refine both meshes and try mapfields it gave me this error in the attached image. i don't know why the mapfields utility failed! i appreciate if someone help me. the attached images are the error appeared to me and the mapfieldsdict. note: phi isn't the flux, it is a volscalarfield i created in my own solver. |
May 6, 2020, 01:26 |
#2 | |
Thomas Sprich
Rep Power: 11 |
In the case for your target mesh, do you have a time folder "3"? Mapfields has to map between the same times in both source and target. I see from your error that the target time is "0" From here: Quote:
Thomas |
different meshes, mapfields |
mapFields utility | rvl565 | OpenFOAM Pre-Processing | 2 | December 29, 2019 09:01 |
Using the mapFields utility | sweisenb | OpenFOAM Pre-Processing | 2 | May 18, 2015 16:54 |
Difficulty with mapFields utility | rnburne | OpenFOAM Pre-Processing | 0 | June 2, 2014 17:33 |
The -parallel parameter of mapFields utility in OpenFOAM v2.3.0 | shuoxue | OpenFOAM Pre-Processing | 1 | April 28, 2014 06:59 |
mapFields utility | openfoammaofnepo | OpenFOAM | 2 | June 29, 2013 17:55 |
