May 2, 2020, 08:44 |
WaveTransmissive
Arkadiusz Drabik
Hey,
I'm relatively new to OpenFoam and I'm simulating a supersonic nozzle. In my case I used the waveTransmissive BC. This condition needs however to give some value. Since I initialize with a temperature difference I want to calculate the pressure rather than estimating it. But I read waveTransmissive can be implemented on other fields as well so I tried it on T. The case worked and gave some good results but I'm not sure if I really can do so? And if it's right what should I write in fieldInf? Values for the p field? |
wavetransmissive bc |
WaveTransmissive BC at inlet | allenjohngeorge | OpenFOAM Pre-Processing | 2 | July 15, 2022 09:41 |
wavetransmissive boundary for pressure and velocity | SanchoPanza | OpenFOAM | 5 | June 29, 2021 07:48 |
BC waveTransmissive in sonicLiquidFoam | philferdinand | OpenFOAM Running, Solving & CFD | 5 | December 3, 2018 05:51 |
OpenFOAM: MRFSimpleFOAM with waveTransmissive | hm86 | OpenFOAM Running, Solving & CFD | 1 | October 12, 2014 02:17 |
waveTransmissive: does fieldInf fix static or total pressure? | Intrepid | OpenFOAM Pre-Processing | 0 | March 31, 2014 13:15 |
