chtMultiRegionFoam with several region of solid one of flui composed by several pipes |
March 6, 2020, 05:44 |
ivan lonati
Rep Power: 9 |
Hello to every one,
I am working on a chtMultiRegionFoam simulation on OpenFOAM 7. There are 20 different regions: 14 are channels with the same fluid and the remaining 6 are solid, all of these with different properties. This is a 3D simulation. I built mesh using ANSYS, so the first step was to convert the mesh using fluent3DMeshToFoam. After that, I launch splitmeshregions -cellzones -overwrite. This command creates my 20 regions All the fluid regions as the same BCs and properties. I am wondering if I can collect all these 14 channels under one single region. I tried to search over splitmeshregion, but I was not able to figure out the problem. Thank you for your help. |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
Negative initial temperature error (chtMultiRegionFoam) | jebin | OpenFOAM Pre-Processing | 60 | July 17, 2022 06:10 |
chtMultiRegionFoam connection between solid and fluid region of heat exchanger | ahab | OpenFOAM | 1 | December 18, 2019 01:37 |
p_rgh initial residual no change with different settings | manuc | OpenFOAM Running, Solving & CFD | 3 | June 26, 2018 16:53 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
