symmetryPlane slows down computation
Old   February 11, 2020, 16:01
Default symmetryPlane slows down computation
Josh McCraney
joshmccraney is on a distinguished road
Hi FOAMers!
I am simulating a case in interFoam, where I create the mesh via snappyHexMesh. Rather than create the entire geometry, I create half, closing it with a wall (all stl files from solid works). When I impose symmetryPlane on this wall, the simulation runs so much slower than if I model the entire geometry and do not exploit symmetry.
Can anyone help? I'm happy to post any info that you ask for, but currently am completely clueless as to why the simulation is taking so long.
joshmccraney is offline   Reply With Quote
Old   February 11, 2020, 16:27
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
is it possible for you to attach a test case? difficult to judge otherwise.
HPE is offline   Reply With Quote
Old   February 11, 2020, 16:40
Josh McCraney
Absolutely. You can download the entire zip file is here.
From there, to run the case, simply navigate into the "case" directory and execute
>> sh reRunSim.sh
The stl files are located in the "geometry" directory. snappyHexMesh is performed in the "mesh" directory. To run snappy (takes 90 seconds), navigate into the "mesh" directory and execute
>> sh runMesh.sh
Let me know if you see anything glaringly wrong. I appreciate your time!
EDIT: I just ran this same case, but instead of symmetryPlane, I used type patch, and had the conditions identical to that of the tank patch. It still goes slow. Then the issue isn't the symmetryPlane, but something else. Any idea if this is a solidWorks issue or a snappyHexMesh issue?
Old   February 20, 2020, 14:37
Josh McCraney
Hi HPE, have you been able to check out my case and see what the issue is regarding the meshing and slow computational time?
symmetryPlane boundary conditions UHGAR OpenFOAM Running, Solving & CFD 2 June 25, 2019 06:33
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
[Other] Override symmetryPlane Boundary condition gwj_gavin OpenFOAM Meshing & Mesh Conversion 0 December 1, 2014 17:46
Divergent temperature in chtMultiRegion(Simple)Foam akrasemann OpenFOAM Running, Solving & CFD 13 March 24, 2014 03:54
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
