Using Ansys mesh for foamextend conjugate heat transfer |
Reza
Rep Power: 14 ![]() |
I have a Ansys mesh of my geometry (a ".msh" file) and I want to import the mesh into my foamextend case file (and not OpenFOAM) to solve a "conjugate heat transfer" problem. for simplicity lets say I want to use "conjugateHeatSimpleFoam". So, my issue is how I can convert the Ansys mesh to be able to run the conjugateHeatSimpleFoam case file. It seems that the command fluentMeshToFoam is not enough. Can anyone tell me how to convert my mesh. thanks. |
Jochen
Rep Power: 9 ![]() |
if it’s a 3D mesh did you also try: fluent3DMeshToFoam <input-file *.msh> Best Jochen |
Reza
Hi Jochen,
I did try the fluent3DMshToFoam. It does not work. The problem is the solver can not identify the solid part of the mesh. Non of the switches are helping with this issue! regards, Reza |
ansys mesh, conjugate heat transfer, conjugateheatfoam, foamextend |
Error running compiled solver of fireFoam and conjugate heat transfer solver | charles4allme | OpenFOAM Running, Solving & CFD | 2 | April 26, 2019 06:58 |
[ICEM] Conjugate Heat Transfer - Conformal Mesh | rsdevako | ANSYS Meshing & Geometry | 2 | April 1, 2019 11:19 |
Mesh for conjugate heat transfer problem from ICEM CFD | Lokanayaki | SU2 | 1 | September 18, 2018 04:25 |
Quenching simulation : how to set up a conjugate heat transfer between solid&liquid | Rockda | FLUENT | 24 | August 30, 2016 06:33 |
ICEM - mesh generation for conjugate heat transfer problems | tmu | Mesh Generation & Pre-Processing | 0 | March 4, 2016 04:21 |
