mixingPlane averaging schemes in foam-extend 4.1 |
January 28, 2020, 04:30 |
Rep Power: 9 |
I'm running foam-extend 4.1 to use the mixingPlane model in a turbomachinery case.
Studying available papers on this i've found two mixingPlane schemes which seem to be available in earlier versions, but are no longer implemented in foam-extend 4.1. These are:
In older foam-extend version these schemes also appear in the fvSchemes files in some tutorials: Link Does anyone know what happened to it? |
September 2, 2020, 08:44 |
#2 | |
Henrik Johansson
Rep Power: 8 |
Hi Bastian,
I asked Martin Beaudoin back in 2018 the same question and got the following answer: Quote:
version.
/ Henrik Johansson |
foam extend 3.1, foam-extend 4.1, fvschemes, mixing plane, mixing plane model |
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." | lethu | OpenFOAM Meshing & Mesh Conversion | 1 | June 3, 2020 07:49 |
[CGNS] CGNS converters available | mbeaudoin | OpenFOAM Meshing & Mesh Conversion | 137 | December 14, 2018 04:20 |
error with reactingFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 4 | June 22, 2016 02:21 |
decomposePar is missing a library | whk1992 | OpenFOAM Pre-Processing | 8 | March 7, 2015 07:53 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
